Hello, I have two lists, one for the curves, one for the offset and an input for the surface and want to create a output list for all OffsetOnSurface but get the error what is shown in the lower picture. I tried many things but find no solution. Maybe someone has an idea how to work around the error.
Hi, thanks, your script is very good but is there a way to use two for-loops.? The first is for the crv count and the second is for the offsets count (like my test before), because I want that when the offset count is lower that the last value is used for all crv with higher index.
cvr (3) | offset (3) (same count)
[0] | [0]
[1] | [1]
[2] | [2]
crv(5) | offset (3) (higher crv count)
[0] | [0]
[1] | [1]
[2] | [2]
[3] | [2]
[4] | [2]
If you want to use the same logic as Grasshopper when the counts are different, it is easier to use Item than to use List.
Thank you, much easier than my first attempt at working with lists/arrays.
