Rhino.Geometry.Brep.CreateFromSweep() Failure To Produce Result
The following code yields a sweep1 style sweep no problem:
sweep = Rhino.Geometry.Brep.CreateFromSweep(path_curve, profile_curve, True, scriptcontext.doc.ModelAbsoluteTolerance)
However, when I try to use the method with the additional args to create a midered, trimmed, and solid sweep1 it consistently returns None but my args look correct from what I can tell based on the API docs here:
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brep/createfromsweep
Code:
        def SweepFromCurve(nurbs_curve=None, width=default_width, height=default_height):
            """Given an input nurbs_curve/polyline, width number, and height number,
            sweep a rectangle(curve_start_origin/plane, width, height) along the curve,
            get the sweep result as a 3d brep"""
            try:
                if nurbs_curve is None:
                    print("nurbs_curve is None, returning")
                    return None
                path_curve = nurbs_curve.ToNurbsCurve()
                # Create a rectangle profile for sweeping
                # First, get the start point and tangent vector
                t = 0.0  # Start of curve
                start_point = path_curve.PointAt(t)
                tangent = path_curve.TangentAt(t)
                # Create a plane perpendicular to the curve at the start point
                success, perp_frame = path_curve.PerpendicularFrameAt(t)
                if not success:
                    # If we can't get a perpendicular frame, create one manually
                    up_vector = Rhino.Geometry.Vector3d.ZAxis
                    # Make sure the up vector isn't parallel to the tangent
                    if abs(Rhino.Geometry.Vector3d.Multiply(up_vector, tangent)) > 0.99:
                        up_vector = Rhino.Geometry.Vector3d.YAxis
                    x_axis = tangent
                    y_axis = Rhino.Geometry.Vector3d.CrossProduct(up_vector, x_axis)
                    y_axis.Unitize()
                    z_axis = Rhino.Geometry.Vector3d.CrossProduct(x_axis, y_axis)
                    z_axis.Unitize()
                    perp_frame = Rhino.Geometry.Plane(start_point, y_axis, z_axis)
                # Create the rectangular profile
                # Center the rectangle on the curve
                center = perp_frame.Origin
                # Create rectangle corners
                half_width = width / 2.0
                rectangle = Rhino.Geometry.Rectangle3d(
                    perp_frame,
                    Rhino.Geometry.Interval(-half_width, half_width),
                    Rhino.Geometry.Interval(0, height)
                # Convert the rectangle to a curve
                profile_curve = rectangle.ToNurbsCurve()
                # Perform the sweep
                # Create a rail sweep using the profile and the curve
                # sweep = Rhino.Geometry.Brep.CreateFromSweep(path_curve, profile_curve, True, scriptcontext.doc.ModelAbsoluteTolerance)
                # Perform the sweep with additional arguments for mitering and solid geometry
                    rail=path_curve,
                    shapes=[profile_curve],
                    startPoint=path_curve.PointAtStart,
                    endPoint=path_curve.PointAtEnd,
                    frameType=Rhino.Geometry.SweepFrame.Roadlike,  # Use roadlike framing for controlled orientation
                    roadlikeNormal=Rhino.Geometry.Vector3d.ZAxis,   # Use Z axis as the normal reference
                    closed=True,#path_curve.IsClosed,                     # Handle closed paths correctly
                    blendType=Rhino.Geometry.SweepBlend.Local,     # Linear blending between cross-sections
                    miterType=Rhino.Geometry.SweepMiter.Trimmed,      # Use sharp mitering at corners
                    tolerance=scriptcontext.doc.ModelAbsoluteTolerance,
                    rebuildType=Rhino.Geometry.SweepRebuild.NONE,   # No rebuild needed for a simple sweep
                    rebuildPointCount=10,                           # Only used if rebuildType isn't None
                    refitTolerance=scriptcontext.doc.ModelAbsoluteTolerance
                """CreateFromSweep(
                    Curve rail,
                    IEnumerable<Curve> shapes,
                    Point3d startPoint,
                    Point3d endPoint,
                    SweepFrame frameType,
                    Vector3d roadlikeNormal,
                    bool closed,
                    SweepBlend blendType,
                    SweepMiter miterType,
                    double tolerance,
                    SweepRebuild rebuildType,
                    int rebuildPointCount,
                    double refitTolerance
                if sweep:
                    return sweep
                print("sweep failed, returning None")
                return None
            except Exception as ex:
                Rhino.RhinoApp.WriteLine(f"SweepFromCurve Exception: {ex}")
                return None
I would appreciate any tips on what I am doing wrong here (version 8.19),
Thank you so much!
I don’t know if what I’m going to type is expected behaviour or not, but setting start and end point to Point3d.Unset has the sweep work. It is hard to know from just the documentation.
I noticed that when I set one end side to a point the method generates this tapered off sweep.
Btw, you need to set the last two parameters to 0 since you’re not rebuilding nor refitting.
Hi @michaelvollrath - I will try to make time to look at this in the next few days.
– Dale
Thanks @nathanletwory I can repeat that on my end.. the sweep will complete with unset points being passed but it will not yield mitered corners nor will it close the end caps.
closed=True I’m assuming is for the end caps? Perhaps that incorrect?
Thanks @dale, that would be a great help, feels “bugged” but doesn’t mean it isn’t just my user error of course.
Okay I think this part actually is working?
The function just doesn’t automatically clean up the coplanar joins, is that correct?
