Rhino freezes when isolating parts
I am having an issue where when i isolate some parts in my file or if i go to a certain view rhino will stop and think for about 30 seconds.
Not a huge issue but a consistent issue
system info.txt (2.3 KB)
Super annoying. I have the same problem
Same here, although my freeze is just a second or two, but still annoying.
(Working with a V8 file.)
I can say that I have the same issues. isolateing and unisolating is a pretty regular part of the workflow, waiting for more than 10 seconds eveytime disrupts that.
If you have a sample file that exhibits this behavior, I would love to see it so we can try to get it fixed.
Thanks for the reports — I’ve logged this as RH-97840 and started digging into it.
What I can say already: on a synthetic test file, the time Isolate takes scales with the total number of objects in the model, not with how many you selected. Isolating one part out of 100,000 costs the same as isolating half of them — Isolate currently works by inverting the selection and hiding everything else, so it touches every object in the file. I can make Isolate slow that way, but I can’t yet make it take 30 seconds, so there is something about your models I’m not reproducing here.
Things that would help, in rough order of usefulness:
  1. A file. Even one that only half reproduces it. If you can’t post it publicly, upload it at https://www.rhino3d.com/upload — that comes privately to us; just mention RH-97840 in the notes.
  2. Rhino version and platform — Windows or Mac, plus the first few lines of Help > System Information. None of the four reports here say which.
  3. How many objects the file has: run SelAll, read the count in the command line, then press Esc.
  4. Is Unisolate slower than Isolate for you? My measurements say Unisolate should be several times worse than Isolate, and I’d like to know whether that matches what you feel.
  5. @Matt_Thornton — you mentioned that switching to a certain view stalls as well, which is a useful clue. Which display mode is that view in (Wireframe, Shaded, Rendered, …), and does it stall every time you switch to it, or only the first time?
This one is worth fixing properly, so any of the above helps.
System info.txt (2.5 KB)
Here is my system information file. I have uploaded my 3D file to the private link.
The file i sent i am getting a decent lag when isolating.
I am using rhino Beta on a windows 11 set up
in the file i sent there are two block instances, 6 points, 328 curves, 2 surfaces, 20 poly surfaces
