Rhino freezes once I set my custom CPlane inside the workspace. In the video, you can notice the command text in the upper part of the Rhino interface “flickering”; the bug becomes visible from minute 3:28 onward.
The freeze starts after running the Orient command (I also want to point out another issue: when I press 0 to set the origin, sometimes the value is not even written in the command line, and I have to restart the command and try again) or the Line command. Starting from the 0 origin of the CPlane, when setting the Z axis while holding Shift (the blue Z line appears), Rhino freezes.
To unfreeze it, I have to click the Rhino icon in the taskbar, minimizing and reopening the Rhino window without actually closing the program.
I am using Rhinoceros 9. I have not yet checked whether the same issue also occurs in Rhinoceros 8.
Rhino Freeze Bug with Custom CPlane and Z Axis (Shift) – UI Flickering & Workspace Freeze.3dm (1.5 MB)
