No @#$& Sherlock. Similarly to how a screwdriver is generally less efficient than this.
Where do I find this NURBS replacement, which is, minimally, equally effective in all respects, yet faster/easier?
NURBS dominate CAD market. Their main flaw is inability to cope with singularities and extraordinary vertices. Singularity is a vertice where many isocurves converge into a single point, for example, the apex of a cone. Extraordinary vertice is a place where total number of converging isocurves is different than 4 and 6. Singularities and extraordinary vertices are common in objects shaped like animals. If the NURBS object has these vertices, commands manipulating the object may fail. T-splines and subdivision surfaces are new kernels. They are not as mature as the NURBS, but they can cope with the singularities and extraordinary vertices, and they reduce the number of control points twofold in comparison with the NURBS when they describe organic surfaces (animals or plants). Some implementations of T-splines and subdivision surfaces are less accurate than NURBS.
Rhino 7 SubD kernel looks to me like quick, dirty, inaccurate kernel suitable for making organic blobs. It does not look like a revolution that will replace NURBS. I have invented better kernel than T-splines and subdivision surfaces, but I am far too busy to develop it into commercial product.
What is the state of your invention? Have you prototyped it in code and tested it? Or is it a set of concepts which have not been implemented yet?
It is nothing more than basic idea - no coding.
Somehow you are too busy to develop your revolutionary cad kernel while at the same time spending much of your free time raving about it on the forums⦠Isnāt it ironic?
Yes, it is ironic. My real work is orders of magnitude more important than reporting Rhino bugs. I seem to be a perfectionist - any bug in Rhino bothers me so much that I have to report it.
Saving the world: one important job at a time.
No offence, I will gladly admit my scepticism was wrong when your innovation will take over the world.
Is this the same Andrew? That right there is some pretty serious stuff!
Prisoners of gravity, escape to outer space. Become cosmic nomads, the hunters of comets and the gatherers of asteroids. Spin cocoons of steel for your new forests and seas. And when you visit the Earth, step lightly, lest you destroy its fragile beauty.
Can tell about this (your idea) to the developers of the program
Does anyone know of a good tutorial on the use of the wire cut command ?
Thank you,
Andy
Hi @litwinaa - what exactly are you looking for? Do you want to understand how the command works or good use cases for the command? Something else?
Hello Vanessa,
Both to understand how the command works and good uses for it.
Thank you,
Andy
@litwinaa - The command is very useful when you want to trim a solid but you want the result to still be a solid. Hereās the Help file video, Rhinoceros Help.
A link to a tutorial, Rhino Tooltip: Wirecut - YouTube
Attached a clip.
Hello Vanessa,
Thank you very much for the help with this command. I appreciate your comment, clip and links They are helpful.
Thank you,
Andy
Phil Cook explains referencing geometry in Rhino 6 with blocks and worksessions: https://www.youtube.com/watch?v=lUCR0GXygUw
Three comments.
The best way to avoid filleting problems is using Rhino 7 and making all fillets at the same time (using FilletEdge command).
This free Rhino plugin (TutorialPanelPlugin) will improve qualty of your tutorials: New feature request - tutorial pane
There are two kinds of Rhino users: those who push osnap control under the panel and those who do not. I do, and I use dark colors as well.
A tutorial video I saw a while ago stuck with me because I didnāt agree with the information contained within it⦠so when I just now made something similar for myself, I thought it fitting to try to make own:
This is my first tutorial and Iām not super experienced with Rhino, so I bet someone will find something to disagree with in this one as well. ![]()
