Rhino for Windows 90 day trial - limited stl saves?
Hi!
I’m using the Rhino for windows 90 day trial and I cant seem to save in .stl anymore. Is there a limited number of saves while using the trial?
Thanks!
Leiagh
No, there isn’t any limitation set. Are you seeing STL in your file save dialog as an option?
Not anymore whether I try to save as or export, it’s no longer an option.
That sounds like the STL file export plug-in somehow got disabled. Run the PlugInManager command, change the filter to “Disabled Plug-ins”. If you see the STL export plug-in in this list, check the enabled checkbox and restart Rhino.
