Rhino for RC aircraft design?
Hi all,
I’m planning to use CAD to design and build model aircraft, and I’m trying to decide which CAD package would be best suited to the job.
I’ve had a small amount of experience with Fusion 360, but I’ve found it quite frustrating when trying to create nice, smooth surfaces using lofts (profiles and rails). I seem to run into errors fairly regularly, and getting the geometry to behave the way I want can be quite difficult.
My intended workflow is to design the complete model in CAD and then split the geometry into 50 mm stations. These stations would become templates that I can use to cut the aircraft from XPS foam. I’ve attached an example of the sort of station templates I have in mind.
I’ve also attached an example of the type of aircraft I’d ultimately like to design. It’s a composite jet, but I’d be aiming to achieve a comparable level of detail and finish using XPS foam.
The aircraft will also involve quite a bit of engineering rather than simply modelling the external shape—for example:
  • Smooth, tapered ducting with specified cross-sectional areas
  • Internal voids and structures to reduce weight
  • Compartments for electronics and batteries
  • Retractable landing gear
  • Structural components and mounting points
  • Accurately controlled airfoil and fuselage geometry
I’m therefore wondering whether Rhino would be a better fit for this type of work than Fusion 360, particularly given its surface-modelling capabilities and the ability to work with complex shapes.
For anyone who designs RC aircraft or similar models in CAD, what would you recommend? Is Rhino particularly well suited to this workflow, or would I be better off persevering with Fusion 360 (or looking at something like Onshape, Solidworks or another package)?
I’m less concerned about the learning curve and more interested in choosing a system that I can grow into that will let me create complex, accurate aircraft geometry without constantly fighting the CAD software.
Any advice from people who have actually used these packages for aircraft design would be greatly appreciated.
Rhino is well suited for this type of work-
do yourself a favor, grab the 90 day free trial, then go to help>learn Rhino>tutorials and samples>level 1 pdf (and level 2 pdf)
and go through the manuals. If you have some previous cad experience, you should be able to cruise thru them pretty quickly and that will get you up to speed in no time.
then hit our youtube channel for lost of project based learning
Thanks Kyle
I will do just that :slightly_smiling_face: :+1:
Yes, Rhino works perfectly and is better than others, more modern like Plasticity, and since it has a perpetual license, much cheaper than older competitors like Alias, Solidworks , subscriptions. You can extract the closed mesh for STL. I use it a lot for 3D printing. It’s great that you can import points to create airfoils from XFOIL, Profili, DesignFoil and much more like “blocks” or “worksessions”.
Some random projects
2000
2006
2010
2020 Grasshopper, included inside Rhino, lets you make procedural surfaces
Plus, it now has nice PBR rendering capabilities
2020
You can create a quick prototype using Rhino SubD before using NURBS surfaces. It’s excellent for sketching out a general 3D idea (but not as a final product, as it lacks precision):
2021
Yes, make-based learning fist
2021 RC 3mt draft idea
