I use the Razer Nostromo Key pad and a Blackwidow ultimate keyboard for other things than Gaming, I’ve been working for more than 2 years with my keypad and Rhino with no problems, but due to the recent updates for the Synapse and Rhino system became unstable. For some reason system freezes, and then it restarts, showing a screen that there was a system failure. It happens when switching between apps, and switching back to Rhino, I work with Indesign, illustrator, iTunes and Rhino at the same time.
I attached a compressed file with my log files to see if anyone can see the problem, Razer support is doing it’s part, but seeing the log files they concluded it could be a Rhino problem. Leonardo.Bonilla.zip(126.3 KB)
Problem happened in 10.8 also.
My computer epecs are:
Software versions
Rhinoceros version: 5.0 Wenatchee 2013-10-23 (485)
OS X version: Version 10.9 (Build 13A603)
Plug-ins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
Hardware information
Computer hardware
Hardware model: MacPro4,1
Processor: Intel Xeon CPU X5550 @ 2.67GHz
Memory: 32 GB
Architecture: Intel 64 bit
Video hardware
Graphics: NVIDIA GeForce GT 120 OpenGL Engine
Memory: (null)
Screen size: 2560 x 1600
Displays: Cinema HD
USB devices
None
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-8.18.27 310.40.05f01
Render version: 2.1
Shading language: 1.20
Maximum texture size: 8192 x 8192
Z-buffer depth: 24 bits
Maximum viewport size: 8192 x 8192
Implementation settings
Use texture compression: Yes
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
