There are two inconsistencies in Rhino extrude commands that drive me crazy!
If you hover your mouse in the negative C-Plane area and Extrude, and enter a numeric extrude length, positive will go to the negative of the C-Plane and negative will go to the positive. Hover your mouse on the opposite side of the C-Plane and you get the opposite effect.If you do the exact same in Extrude Tapered, that does not hold. Extrude tapered will always go negative with a negative number and positive with a positive number regardless of where your mouse is hovered.
In Extrude Tapered, the positive or negative value of the taper and the result are random. Sometimes a positive value extrudes wider, sometimes narrower. This, contrary to what you are likely thinking, that it depends on the direction to the C-Plane, is not true. It is random as random can be. I have extruded the exact same curve with the exact same value and had it get larger once and smaller the next. This is simply unworkable and drives me CRAZY!!! A positive or negative value should ALWAYS HAVE THE SAME RESULT!
I have brought this up to Tech Support on multiple occasions and I am finally coming to the Forum to get enough support behind this to get what seem like logical solutions to illogical results.
Please chime in on this!!!
By the way, I have been using Rhino for 20 years. Not a newby.
_extrudeCrvTapered is not in my daily toolset, but i remember that i quite often have to change +/- of the DraftAngle.
Maybe - my guesses:
Orientation (CW/CCW), Boundingbox-Center, Curve-Start/End Point matters - beside cplane ?
i agree to wish more consistency on those aspects. Similar inconsistency is how to define direction / or a plane in different commands.
Yes I can add my ugly experince with Extrude Taper.
The interface is messy and the results always poor.
Unfortunately is not a command that has high priority.
