Hi Everyone
I found that rhino export or import problem. I was export one solid to STEP(.stp) file and import that STEP(.stp) file into rhino. Exported solid converted to polysurface why???
Thanks…!
Hi Everyone
Thanks…!
The light-weight extrusion object
is a Rhino-only format. When you export those objects to other formats, they will have to be converted.
Note that you can (sometimes) convert these NURBS objects back into light-weight extrusion object with a script that you can find here:
