I’m getting the following message prompt: Rhino.exe Assert Failure
This happened after installing Rhino Nest 4 trial version or T-splines,
please advise,
thanks
thanks
Neither Rhino Nest or T-Splines are our plug-ins.
I normally would suggest contacting the plug-in developers directly.
This would be smart for Rhino Nest. It was produced by TDM Solutions in Spain, but now are owned by Stuller.
Since T-Splines has been discontinued and abandoned by Autodesk, I doubt you’ll get much help with that.
Hopefully another developer or user that has T-Splnes might be familiar with that error.
Hi John,
The message appeared only in Rhino5 64, just couple minutes ago I removed T-spline and Rhinonest 4, restart laptop and re-enter Rhino5 64, this did not solve the problem, I’m thinking of re-installing Rhino5 64 see if the problem will go away.
Hi again,
It is solved now. I removed the Gate app not rhinoNest, no more message after removing Rhinonest.
thx,
What is the Gate app?
Yes that’s the one.
