Rhino error please help
I have been working on a file for the past three hours and it is stuck in the middle of a command and I haven’t saved it once. I clicked escape and undo and other such things and nothing will work and I cant even click anything on the window it physically wont let me please what do I do. It stopped working 20 minutes ago and the last saved time hasn’t changed once please help me.
Have a look in the Recycle Bin, and see if there are AutoSaves in there. Rhino periodically makes these normally.
it is an untitled file it hasnt been saved once
like i cant even click on the icon on my tool bar at the bottom of my screen it doesnt react or show a preview of anything
Okay. Have you checked the Appdata folder for the Rhino Autosaves as well? Maybe there is something in there?
am I a lost cause
Have a look here:
\Users\YOURNAME\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave
that brings me to a server not found page
Yeah. That’s probably trying to go into the Internet browser. You need to go into the file system and follow your C:\ drive to that directory. Note that Appdata is normally hidden, so you may have to set to showing the hidden folders.
I never have saved the file either I am such an idiot
I’m afraid that it is worse than being an idiot. It is being human. I think nearly everyone here has done this exact same thing. It’s easy to get lost in the work, and forget to save. It won’t be the last time.
I may be stupid but i cant get what you sent me to work, i dont know if its because I am technically challenged or what
like i can only even access the window when i close all other tabs and its the only one left
Okay, let’s make this clearer. :slight_smile:
C:\Users\ <Lauren>\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave
The name between the “<>” will be whatever your user account is, assuming your account is mounted to the C:\ drive.
my file temporarily started to load but the command is still not shutting off the point that I can save I also think I am so dumb i tried what you said word for word and i cant get it to work
David it started to load again and I was able to save it!
That’s good news! Lessons learned, until you forget again, as we all do. Welcome to the forum.
Please check mark your own reply as the solution, so nobody needs to look into this specific problem. :slight_smile:
