When I mirror a solid or polysurface, the resulting object appears only as a set of curves. Even models I created in earlier versions display incorrectly. There isn’t a problem with curves, just surfaces, polysurfaces, and solids.
Has anyone else experienced this?
I’m running OS 10.9 on a 2010 macbook pro 2.53ghz i5
I tired the use extrusions command and switched to poly-surfaces and it didn’t fix the bug. I tried this both before doing the mirror and with the resulting mirrored surface and neither way fixed the issue in my model. I guess I’ll just wait for the fix.
I had this and reported it somewhere before (Missing extrusion surfaces when mirroring). What I was told to do, and worked for me, was to select the offending object, “explode” it, and then immediately “join” it
