Rhino does not select the mesh built in GH
Dear Masters, Hi. I created a mesh in GH but Rhino treats it as I took it out of the fridge and put it there. I can do nothing with it. even cant select it. its there, in rhino working space, but Rhino thinks it comes from another planet. Ur GH created it bro. please let me know if there is some special settings for GH meshes.
flat.3dm (63.5 KB)
Flat.gh (18.1 KB)
You were using the vertices of exploded polylines for your delunay mesh construction - this includes duplicate points - for polylines it’s best to use discontinuity points:
Flat.gh (18.3 KB)
*typo on ‘merge’ group: Simplify not ‘simply’
Thank u for ur attention. but all the meshes have the same problem. this little sphere is created by GH mesh primitive. its not selectable too
Unti44tled
Hmm - I guess I’m not following! Do you simply want to select it (as in, click on it, in the Rhino space, not grasshopper)? If yes then the mesh must be baked into Rhino first!
oah it seems I’m discovering the point. I want to convert the mesh to surface after using Quad remesh and making a handsome mesh, and then flow this pattern over a revolved surface. thats what i wanna do if i could explain it in a nice way
I see - I think it’s explained well enough - thank you.
Well,
Yes :wink:
Feel free to ask once you get there!
WoW i baked it and it moves and can be selected now. thank u soooo much. im going to move it for a while because i just tried so much to move it and it was frozen there. i just clicked the fried egg one. thank uuuu
Hi again. can i still ask questions?
If you use rhino 8 then you can use content cache: Content Cache Updated Guide
i use rhino 7 now. thank u auto answer
You can learn more about Grasshopper in this primer:
https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-1/0_hello-grasshopper.html
thank u Sensei
