I have just tried to compile the Rhino Skin example I found here:
Everything goes well but I cannot understand why, when I run Rhino, a display message says:
“Your Rhino 5 plug-ins may have updates available to run in Rhino 6”.
It is due to the custom skin because if i disable it, the message doesn’t appear.
I tried to create another personal custom skin but the problem persists. I looked for something in the code reporting the wrong version but I found nothing:
I compiled the code using Visual Studio 2017, used the Rhino c++ sdk 6,19,19295,1001 and used the skin on Rhino 6 SR26 (6.26.20147.6511, 26/05/2020).
Do you have any ideas about what can produce this issue?
Many thanks!
