Rhino curve/surface anatomy
Hello Gijs, Thank you very much for writing this practical tool, it’s fantastic. If we could add a dot index in the u and v directions, it would be even more perfect. Sometimes we hope to see the sorting index of the dots to provide users with a better experience.
I’m not understanding. Here you’re showing a curve, so there is no v direction. Why would this help? To determine the curve direction, or something else?
That’s a great idea, Alias indicates curve-U and surface-U/V with a special CV, so you instantly see the direction of a curve or surface. Should be easy to implement.
This actually is a clever, minimalist way to show that information.
Would love to see something like that implemented.
I would rather have proper circle control points and edge markings for the U and V directions. Some users also prefer to have square control points.
I always liked that- Alias has some really nice UI stuff
RH-91541 is fixed in Rhino WIP
FYI it was decided that this command needed to be turned back to test command shortly after it was changed to normal command.
Still one of my “life savers”, so useful.
I added “NoEcho” and “Echo” to remove the extra rows of text from the Command line history.
NoEcho ConvertToBeziers Pause N Enter None Sellast -group temp enter Intersect None -selgroup temp enter delete Echo
