Rhino creating wrong mesh out of set of curves
Hello, so a couple of days ago I updated rhino8 for Mac and started drawing a simple road and sidewalk project to help a friend, I traced on a google earth image with polyline, the curves looked smooth but when creating a planarsrf it created new curves, when trying to extrude with gumball or push pull it would create a wrong mesh. This has only happened since the new update, I tried starting from a new file but the problem persists. Here are some examples. . Has anybody else been experiencing this?
This a sequence of me creating the planarsrf out of the curves, and extruding. as you can see new lines come up.
This is another example, the mesh and the outline of the object don’t match.
Hi, @Sam_Delic. Welcome to the forum!
It’d be helpful it you attached your file or something similar that has the same problem for us to test with. Also, describe your exact process step-by-step, so we can attempt to replicate the issue.
