Rhino Crashing on Print Command (Rhino 8)
Hello, uni student here trying to export my layout with ‘Print’ command but each time I do so, Rhino crashes. I have tried turning on/off my OpenGL setting, resetting all Rhino settings and it seems any Rhino file (even empty) will crash :frowning:
I am using Rhino 8 and system info is below, any help would be greatly appreciated. Thank you!
Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11001, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
License type: Educational Lab License, build 2026-04-13
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 15GB)
.NET 8.0.21
Primary display: AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 9-25-2024 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 6141 MB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.7.4.0
C:\Users\joaqu\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggKaramba\25.6.11.8\ggKarambaIFC.rhp “ggKarambaIFC” 25.6.11.8
C:\Users\joaqu\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.60309\net8.0-windows\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.30.26103.11001
Hi @Joaquin3,
I do not see any crash reported submitted with your email. When Rhino crashes, are you filling out and submitting the crash report?
Thanks,
– Dale
Hi Dale
No I’m not, the layout screen freezes and Rhino exits on its own. I’m wondering if it’s worth to uninstall and reinstall to see if that works? But my Rhino is up to date.
Thank you!
Hi @Joaquin3,
Do you see any recent “Rhino[xyz].dmp” files in this folder:
%LOCALAPPDATA%\CrashDumps
If so, can you zip it and sent to our tech staff using this tool?
https://www.rhino3d.com/upload
– Dale
Uploaded the zip file now with the latest dmp file
Zip folder name: Rhino 8 Crash File.zip
Thanks again :slight_smile:
Hi @Joaquin3,
This is what I am seeing:
Unhandled exception at 0x000001DCEBB1C774 (SU2HUD.DLL) in Rhino.exe.14128.dmp:
0xC0000417: An invalid parameter was passed to a C runtime function.
Perhaps this issue is related to yours?
– Dale
Hi Dale,
Thank you for your help, I had to remove any existing printers known on my laptop, restart and then reconnect the printers. All good now :slight_smile:
