Hy there,
I have been experiencing this already for quite a while:
When I switch a larger model from wireframe to shaded display mode and I hit “exc” during the “creating meshes…” operation Rhino will crash immediately…
Yours
Dominik
Hy there,
Yours
Dominik
Sorry for the convenience. Can you provide any details about your system, your video card, and your Rhino version?
Taking a screen capture of Rhino’s OpenGL page might also be helpful.
Hy Dale,
here are more informations about my running system:
Rhino:
Version 5 SR12 64-bit
(5.12.50810.13095, 8/10/2015)
Not For Resale Lab
OS:
OpenGL/ video card:
Anything else needed?
Yours
Dominik
Hi Dominik,
Thanks for the info - all looks pretty normal.
Are you crashing with a particular model, or do all models crash when switching from wireframe to shaded? Also, are you using any 3rd party plug-in? If so, have you tried to disable them (Tools -> Options -> Plug-ins) to see if one of them is causing the crash?
– Dale
Hy Dale,
it is not with a particular model unfortunately. I have not yet figured out on which models Rhino crashes. Mostly these are larger models when it takes a while for Rhino to create the render meshes. Then when I hit “esc” it crashes.
So far I haven’t tested if one of my thirdparty plugins might cause the crash. I have several installled though. I will check.
Yours
Dominik
