This week I discovered Rhino 8 was unable to start except in Safe Mode. After some trial and error, I’ve been able to keep it from crashing by one of three ways:
- Disabling Rhino Cycles plugin,
- Disabling Rhino Cycles GPU mode (RhinoCyclesDisableGpu, run RhinoCyclesEnableGpu to reverse it),
- Disabling Optimus in the BIOS, connecting the monitor/dock to the USB-C ports managed by the Nvidia adapter, and then disabling the Intel display driver in Device Manager.
If I disable the Intel display driver before disabling Optimus, Rhino will run but only in OpenGL 1.1. Weirdly, if having disabled Optimus I then uninstall the Intel Driver (and remove it by command-line), Rhino will still crash until I disable the Microsoft Basic Display Driver that took its place. It also crashes if both drivers are uninstalled, though I imagine it would work if I disabled the one that replaces Intel but left the other one going…
So far, the solution I’ve settled with is #3. This is a workstation laptop, it’s usually plugged into power, and I always want to use the Nvidia video adapter anyway.
At one point I had Optimus enabled, but I also enabled Direct Output Mode. As far as I can tell, this is similar to turning off Optimus completely except the main laptop screen remains with Intel. Turning the Intel driver off in this state would either: de-activate that screen or, leave it on somehow and make everything on every screen choppy. What it did seemed left up to chance so at that point I gave up on Optimus completely.
I’m not surprised this is happening. Windows Update screwed up the Intel driver a week ago, forcing everything into software rendering until the driver was updated. Everything else still worked after that, including Blender. Only Rhino remained affected. From a search here I see I’m not the only one who’s had that experience.
The system’s a Dell Pro Max 18 Plus MB18250, here’s the output from System Info:
Rhino 8 SR33 2026-7-7 (Rhino 8, 8.33.26188.13001, Git hash:master @ 482f88a83547c62cde64d78ea8a8690b7349f289)
License type: Commercial, build 2026-07-07
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63GB)
.NET 8.0.21
Primary display and OpenGL: NVIDIA RTX PRO 4000 Blackwell Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 7-10-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 596.86
Integrated accelerated graphics device with 4 adapter port(s)
- Secondary monitor attached to adapter port 1
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX PRO 4000 Blackwell Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 7-10-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 596.86
Secondary graphics devices.
[DISABLED] Intel(R) Graphics (Intel) Memory: 2GB, Driver date: 7-17-2026 (M-D-Y).
Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-10-2026
Driver Version: 32.0.15.9686
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.33.26188.13001
Here’s a graphics configuration from earlier, before I switched off Optimus, switched ports, and updated the Intel driver:
Primary display: Intel(R) Graphics (Intel) Memory: 2GB, Driver date: 4-16-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
(At some point that worked, but then it stopped working… probably when Windows broke the Intel driver.)
Before figuring this stuff out I also did several other things:
- Tried to update Windows (it’s fully updated),
- Updated Nvidia video driver,
- Repaired every Visual C++ Redistributable,
- Uninstall and re-installed every Visual C++ Redistributable,
- Installed Visual C++ Redistributable version 14.44.35211 (had to uninstall 14.51.36247 to do this, and I put it back when it didn’t work),
- Deleted the Rhino Cycle shader cache,
- Uninstall and re-installed Rhino 8 (deleted registry keys and lingering file directories),
- Reset default windows layout in Rhino,
- Ran the reset command,
- Installed Rhino 8 BETA,
- Disabled Optimus in the BIOS (this didn’t work at first because the dock/hub remained on the wrong port and I still had the Intel driver enabled),
- Loaded Cycles while in safe mode and clicked Reset Defaults.
Although it’s all fine now, I would like to not need to leave Intel video disabled. That feels like a half-baked solution. I’ll try anyone’s suggestions if they have an idea.
