It crashes all the time. I have updated my drivers and it shoudl work fine. I have windows 11.
Hej Elin -
Please run the Rhino SystemInfo command and copy-paste its output here.
Hello, here it is copy pasted: Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Educational Lab License, build 2026-09-08
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.24
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 9-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 616.92
Accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-4-2026
Driver Version: 32.0.16.1692
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
Hej Elin -
Please disable V-Ray in the Rhino plug-in manager and then restart Rhino.
Does that make a difference?
Apart from that, I don’t see crash reports from your account here. Does the Rhino crash reporter pop up when it crashes?
Hello, it unfortunately did not work. I will paste the crash log here. When rhino crashes it sometimes gives me a pop up about it.
/Elin
(attachments)
RhinoCrashDump.3dm (28.6 KB)
Hi Elin -
That 3dm file isn’t a crash log.
Since it sounds easy for you to reproduce the crash, please make it crash again, take a screen shot, and post that here. With the pop up visible.
Hello. Here is the screenshot of the crash and the report from the windows reliability monitor. The windows smart app control is not enabled on my pc. Källa
Rhino 8
Sammanfattning
Slutade fungera
Datum
‎2026-‎09-‎17 08:13
Status
Rapport skickad
Beskrivning
Felaktig programsökväg: C:\Program Files\Rhino 8\System\Rhino.exe
Problemsignatur
Händelsenamn: APPCRASH
Programnamn: Rhino.exe
Programversion: 8.35.26251.13001
Programtidsstämpel: 6aa0710e
Namn pĂĄ felmodul: StackHash_7433
Modulens version: 10.0.26100.9444
Tidsstämpel för felmodul: 6bdf03ca
Undantagskod: c0000374
Undantagsförskjutning: PCH_91_FROM_ntdll+0x0000000000161914
OS-version: 10.0.26200.2.0.0.768.101
SprĂĄkvariant-ID: 1053
Ytterligare information 1: 7433
Ytterligare information 2: 7433d90d586e1496ea0e9bc7a5260f8a
Ytterligare information 3: 41bd
Ytterligare information 4: 41bd5d24a3b0ab2f57678b5fed9ae33e
Extra information om problemet
Bucket-ID: 045042b3823b4630789e3e078c2d8933 (1773923505368041779)
Thanks,
- Faulting app: C:\Program Files\Rhino 8\System\Rhino.exe, 8.35.26251.13001 (SR35, current)
- Exception code c0000374 — STATUS_HEAP_CORRUPTION
- Faulting module: StackHash_7433, offset PCH_91_FROM_ntdll+0x161914, ntdll 10.0.26100.9444
Unfortunately StackHash_7433 means Windows could not attribute a module.
Disabling Vray could still have .dll’s loading.
Can you repeat the issue when Rhino is opened in Safe Mode?? Search Rhino 8 in Safe Mode on windows
It’s the same issue in Safe Mode as in the regular mode. Whenever I try to make the window larger horizontally (or switch to full screen), Rhino instantly crashes. I also only have one monitor connected.
/Elin
not running in safe mode and the system level crash is pointing to some sort of windows issue or conflict. Are you up to date on windows?
Hello, it’s up to date from what I can see.
I’d try a Rhino repair and see if that resolves the issue.
I’ve done that too and it doesn’t work either unfortunately.
Hej Elin -
What I was wondering about is if the Rhino crash reporter ever shows up when Rhino crashes. That would be the one with the drawing of a rhino and a punctured beach ball.
Yes that window does pop up when rhino crashes.
Sending in that report will help tremendously in finding what’s causing it.
Hi @Elin_Andersson,
The crashes are caused by the ASUS GPU Tweak III application installed in your system.
How to Fix It
- Turn off the Overlay: Open the ASUS GPU Tweak III desktop software and toggle the OSD (On-Screen Display) feature completely Off.
- Blacklist Specific Apps: If you only want to stop it from crashing a specific game or work program, use the software’s Profile Connect or OSD settings to blacklist that specific
.exefile from overlay injection. [1] - Update the Software: Ensure you are running the latest stable build (v2.1.8.0 or newer), as ASUS frequently pushes patches to fix driver conflict hooks. [1]
- Clean Uninstall: If the crashes persist even with the OSD off, the background injection services may still be running. Completely uninstall GPU Tweak III from your system via Windows Settings, reboot your compute.
Hope this helps,
– Dale
