Rhino crashed when drawing 3d faces in sub d
Hello
my rhino crashed while manually drawing 3d faces in sub d approx. after the 30th face. The Programm just freezes.
Is this happening to others too?
Hi -
I’m not seeing that here, no.
Please run the Rhino SystemInfo command and copy-paste the result here.
Also, when Rhino hangs / freezes, you can upload a dump file using the instructions on this page: Manually Creating a Memory Dump (DMP File) from an Unresponsive Rhino for Mac [McNeel Wiki]
No, works fine
Spindump.zip (259.5 KB)
it is unfortunately still happening also after reinstalling rhino and all the plugins :frowning:
system info.txt (5.6 KB)
Hi David -
Thanks for that file. I see that you also sent that in and that someone will take a look.
Hey Wim thanks for your help!
It seems to work now dont ask me why :slight_smile:
maybe because of the reinstall
it crashed 10 times in a row also when opening a new file.
i hope this will last
best regards david
