Rhino Crash With WebView ExecuteScript
I’m testing out using webview in ETO in Rhino8 and I keep crashing Rhino when using the ExecuteScript function inside of the DocumentLoading Event. I can successfully inject the JavaScript once and then Rhino crashes. Any help would be appreciated. Thanks.
using Eto.Drawing;
using Eto.Forms;
using System;
using Rhino;
namespace TestWebUI
    public class EtoForm : Form
        public WebView Wv { get; private set; }
        public bool IndexLoaded = false;
        string index;
        public EtoForm()
            this.ClientSize = new Size(600, 600);
            Wv = new WebView();
            Wv.DocumentLoading += E_DocumentLoading;
            Wv.DocumentLoaded += E_DocumentLoaded;
            Content = Wv;
        private void E_DocumentLoaded(object sender, WebViewLoadedEventArgs e)
            if (e.Uri.AbsolutePath == index) IndexLoaded = true;
        public void SetWVUrl(string url)
            index = url.Replace("\\", "/");
            Wv.Url = new Uri(index);
        private void E_DocumentLoading(object sender, WebViewLoadingEventArgs e)
            if (e.Uri.Scheme == "myapp")
                e.Cancel = true; // Cancel Any Other Navigation
                var path = e.Uri.PathAndQuery;
                RhinoApp.WriteLine(path);
                // change the button text to the path with injected javascript
                string js = $"document.getElementById('greetingsbutton').innerText = '{path}';";
                Wv.ExecuteScript(js);
Hi @David_Moreau ,
using Eto.Drawing;
using Eto.Forms;
using Rhino;
using System;
namespace TestWebUI
    public class EtoForm2 : Form
        string index;
        private string path;
        public EtoForm2()
            Wv = new WebView();
            SetWVUrl("https://www.google.com");
            Content = Wv;
            if (e.Uri.AbsolutePath == index && !string.IsNullOrEmpty(path))
                IndexLoaded = true;
                // Execute JavaScript here, after the document is fully loaded
You were attempting to execute JavaScript in the DocumentLoading event. This event is triggered before the document has finished loading.
Hope this helps,
Farouk
Brilliant. Thank you!
