Rhino crash when i try to create a new floating view
Hi, As the title says, my Rhino7 has crashed when I try to create a new floating view.
Does anyone have the same issue as this?
1
Hi -
That seems to be working fine here.
Is this with a new, and empty, document or is this file-related?
Does it also crash when you use the NewFloatingViewport command instead of dragging to create a copy of the viewport?
From your crash report, I see that you are running a few 3rd plug-ins. I would go to the PluginManager and disable Cyberstrak and the 3 KeyShot plug-ins and restart Rhino to see if that makes the crash go away.
Thanks wim, you are correct. It works fine now after I disable the Cybestrak.
Thanks. You might want to contact the developer of that plug-in so that this gets addressed.
This started happening to me too. Can confirm disabling Cyberstrak solves the issue.
Hi there,
do you use the latest download (version 1.2) of the Cyberstrak PlugIn? I think it happens in version 1.1, but in 1.2 can’t reproduce it here. Download: Downloads - Cyberstrak
  • Peter
Thanks Peter,
Updated to V1.2 and the problem has gone.
