My thanks to Jim Carruthers for kindly pointing out my rant - that’s the way I actually see it - making me realize my post was not helpful [yes, I agree with you], just frustration after a %^ week of whatever - not anyone’s problem but mine. Sorry, already stated with second post. But I find myself wanting to be clear, but I digress.
In my second post I tried a bit more of a scientific approach attempting to describe exactly what my issue is - using nomenclature I might be incorrectly using, the viewport and the construction plane such as when I type in an explicit line - using NO shortcuts of any kind - what occurs. Step by step. Hoping to provide what I should have the first time as requested.
Here I am still frustrated, now after several videos, several manual look overs and tries, about four hours in I think I now have the cPlane, construction planes [viewports?] and even the gumball messed up. Up is down, left is right, gumball is…
Before any more, would like to state when I first hit this issue - most likely my own errant keystroke but - I searched and found MANY videos, forum posts, reddit posts, youtube posts…all described part or ? my issue. Seems this may have [guessing] occurred with the last update I installed inclusive of a new “feature” autocplane…maybe not, I do not know for sure, if I can’t fix my issue I surely am not the one to tell anyone what it is, but the evidence points that way. I see many stating it should not have been enabled by default - those with a lot better use of features than myself. I was fine, using the standard viewports and never used cplanes or gumball moves. Thousands of drawings under my belt since V5, I then export stls and dxfs to my CAM [meshcam and deskproto] so I can cut on my CNC. So I do not think I am a newbie, just not that advanced when it comes to all the bells and whistles.
McNeel, it would be nice to have a “reset” for all of the views, cplanes, gumball…as they are the one interface a user must use, or post a script for it - but it really should be a one click, I think it may even be good for beginner use of cplanes and such - maybe I would have learned more if I knew how to get back to square one and did not wish to experiment and get trapped - hey, here I am…
So telling me how to draw a line - useless. That’s not a directed comment, just the truth. Why I used the exact procedure I spelled out was because I was asked - again, thank you for even keeling me Jim - and I thought I’d do MY best with my limited knowledge to explain.
It appears I may just need to reinstall and then make sure autocplane and sticky are turned off. My final comment is as a user and paying software customer, seems a long path to get to square one. I just hope when I do that later today, it actually works to correct my issue.
