Rhino.Compute + .NET Framework Runtime
Hi everyone,
I used preinstalled rhino.compute in c:\Users\kukol\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Hops\0.16.7\rhino.compute\ and everything worked great before I switched Runtime to .NET Framework to support ggKaramba plugin.
After switching rhino.compute does not start properly:
Coould you please advice how to fix it in my setup with Runtime = .NET Framework?
Compute does not run with .NET Framework with Rhino 8 and only runs with .NET Core. If Karamba requires .NET Framework, then it will not work with compute in Rhino 8.
