Rhino.Compute Linux Fonts
@fraguada im currently trying to get my plugin working that needs a specific font for laser cutting. Now I tried to install the font on linux but somehow rhino.compute is not picking up any font at all. Is there a font api from rhino core that I could tap into or something totally else that I could make this work? I tried also to internalise the font into the plugin wich works on windows but somehow not on linux as well. Another thing would be also the dimensions from rhino…
Or if anyone else already ran into that problem?
Best and thank you already in advanced!
If you can share some code related to how you are trying to use the font, I can try to debug from my side.
@fraguada Attached you find a grasshopper definition that should generate TextCurves out of dimensions. In this example I just use Arial wich I thought I installed on the linux docker image but somehow it is not generating the TextCurve for the dims.
TextTest.gh (11.7 KB)
Hi @felix.brunold, did you manage to fix this? I’m running into the same issue with linux compute.
Echoing that I’m encountering this now too. Here’s the error/trace I get trying to run IGH_Param.CollectData() on the output Brep param of Text on Surface component:
System.Exception: Could not create any valid text shapes.
at FieldComponents.TextOnSurfaceComponent.SolveInstance(IGH_DataAccess DA) in /scratch/buildAgent/work/db0f3a602490518c/src4/rhino4/Plug-ins/Grasshopper/Components/FieldComponents/TextOnSurfaceComponent.cs:line 68
at Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it) in /scratch/buildAgent/work/db0f3a602490518c/src4/rhino4/Plug-ins/Grasshopper/Grasshopper/GH_Component.vb:line 1250
Hopefully provides some useful hints. This is with the default inputs for the component (font is “Sans Bold:no Italic:no”)
Linux machine’s output of fc-list is:
/home/chuck/.local/share/fonts: skipping, no such directory
/usr/local/share/fonts: caching, new cache contents: 0 fonts, 0 dirs
/usr/share/fonts: caching, new cache contents: 0 fonts, 1 dirs
/usr/share/fonts/truetype: caching, new cache contents: 0 fonts, 4 dirs
/usr/share/fonts/truetype/dejavu: caching, new cache contents: 8 fonts, 0 dirs
/usr/share/fonts/truetype/liberation: caching, new cache contents: 16 fonts, 0 dirs
/usr/share/fonts/truetype/noto: caching, new cache contents: 271 fonts, 0 dirs
/usr/share/fonts/truetype/ubuntu: caching, new cache contents: 232 fonts, 0 dirs
/var/lib/snapd/desktop/fonts: skipping, no such directory
/home/chuck/.fonts: skipping, no such directory
/usr/share/fonts/truetype: skipping, looped directory detected
/usr/share/fonts/truetype/dejavu: skipping, looped directory detected
/usr/share/fonts/truetype/liberation: skipping, looped directory detected
/usr/share/fonts/truetype/noto: skipping, looped directory detected
/usr/share/fonts/truetype/ubuntu: skipping, looped directory detected
/var/cache/fontconfig: not cleaning unwritable cache directory
/home/chuck/.cache/fontconfig: cleaning cache directory
/home/chuck/.fontconfig: not cleaning non-existent cache directory
fc-cache: succeeded
chuck@LONDON-SURFACE:~$ fc-list
/usr/share/fonts/truetype/dejavu/DejaVuSerif-Bold.ttf: DejaVu Serif:style=Bold
/usr/share/fonts/truetype/noto/NotoSansThai-Regular.ttf: Noto Sans Thai:style=Regular
/usr/share/fonts/truetype/noto/NotoSansModi-Regular.ttf: Noto Sans Modi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansPahawhHmong-Regular.ttf: Noto Sans Pahawh Hmong:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifYezidi-Bold.ttf: Noto Serif Yezidi:style=Bold
/usr/share/fonts/truetype/noto/NotoSansOldNorthArabian-Regular.ttf: Noto Sans Old North Arabian,Noto Sans OldNorArab:style=Regular
/usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf: DejaVu Sans Mono:style=Book
/usr/share/fonts/truetype/noto/NotoSansCypriot-Regular.ttf: Noto Sans Cypriot:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Italic
/usr/share/fonts/truetype/noto/NotoSansPsalterPahlavi-Regular.ttf: Noto Sans Psalter Pahlavi,Noto Sans PsaPahlavi:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=SemiBold Italic
/usr/share/fonts/truetype/noto/NotoSansWarangCiti-Regular.ttf: Noto Sans Warang Citi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLisu-Regular.ttf: Noto Sans Lisu:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSogdian-Regular.ttf: Noto Sans Sogdian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMongolian-Regular.ttf: Noto Sans Mongolian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLimbu-Regular.ttf: Noto Sans Limbu:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Thin
/usr/share/fonts/truetype/noto/NotoSansUgaritic-Regular.ttf: Noto Sans Ugaritic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMono-Regular.ttf: Noto Sans Mono:style=Regular
/usr/share/fonts/truetype/noto/NotoSansKhmer-Bold.ttf: Noto Sans Khmer:style=Bold
/usr/share/fonts/truetype/noto/NotoSansArmenian-Bold.ttf: Noto Sans Armenian:style=Bold
/usr/share/fonts/truetype/noto/NotoSansGujarati-Bold.ttf: Noto Sans Gujarati:style=Bold
/usr/share/fonts/truetype/liberation/LiberationSansNarrow-Italic.ttf: Liberation Sans Narrow:style=Italic
/usr/share/fonts/truetype/noto/NotoSansOriya-Regular.ttf: Noto Sans Oriya:style=Regular
/usr/share/fonts/truetype/noto/NotoSansWancho-Regular.ttf: Noto Sans Wancho:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCaucasianAlbanian-Regular.ttf: Noto Sans Caucasian Albanian,Noto Sans CaucAlban:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifHebrew-Bold.ttf: Noto Serif Hebrew:style=Bold
/usr/share/fonts/truetype/noto/NotoSansInscriptionalParthian-Regular.ttf: Noto Sans Inscriptional Parthian,Noto Sans InsParthi:style=Regular
/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf: DejaVu Sans:style=Book
/usr/share/fonts/truetype/noto/NotoSerifHebrew-Regular.ttf: Noto Serif Hebrew:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMayanNumerals-Regular.ttf: Noto Sans Mayan Numerals:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTakri-Regular.ttf: Noto Sans Takri:style=Regular
/usr/share/fonts/truetype/noto/NotoSansAdlamUnjoined-Bold.ttf: Noto Sans Adlam Unjoined:style=Bold
/usr/share/fonts/truetype/noto/NotoSansSignWriting-Regular.ttf: Noto Sans SignWriting,Noto Sans SignWrit:style=Regular
/usr/share/fonts/truetype/noto/NotoNaskhArabic-Bold.ttf: Noto Naskh Arabic:style=Bold
/usr/share/fonts/truetype/noto/NotoSansTifinaghHawad-Regular.ttf: Noto Sans Tifinagh Hawad:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifTelugu-Regular.ttf: Noto Serif Telugu:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCuneiform-Regular.ttf: Noto Sans Cuneiform:style=Regular
/usr/share/fonts/truetype/noto/NotoRashiHebrew-Regular.ttf: Noto Rashi Hebrew:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed Bold Italic
/usr/share/fonts/truetype/liberation/LiberationSans-Regular.ttf: Liberation Sans:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifTamil-Bold.ttf: Noto Serif Tamil:style=Bold
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSyriac-Regular.ttf: Noto Sans Syriac:style=Regular
/usr/share/fonts/truetype/liberation/LiberationMono-BoldItalic.ttf: Liberation Mono:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSansTifinagh-Regular.ttf: Noto Sans Tifinagh:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSoraSompeng-Regular.ttf: Noto Sans Sora Sompeng:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifDisplay-BoldItalic.ttf: Noto Serif Display:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSansOlChiki-Bold.ttf: Noto Sans Ol Chiki:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifTamil-Regular.ttf: Noto Serif Tamil:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifBalinese-Regular.ttf: Noto Serif Balinese:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMyanmar-Bold.ttf: Noto Sans Myanmar:style=Bold
/usr/share/fonts/truetype/liberation/LiberationSerif-Italic.ttf: Liberation Serif:style=Italic
/usr/share/fonts/truetype/noto/NotoSerifGurmukhi-Bold.ttf: Noto Serif Gurmukhi:style=Bold
/usr/share/fonts/truetype/noto/NotoLoopedThai-Bold.ttf: Noto Looped Thai,Noto Looped Thai Bold:style=Bold
/usr/share/fonts/truetype/noto/NotoSansMarchen-Regular.ttf: Noto Sans Marchen:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSaurashtra-Regular.ttf: Noto Sans Saurashtra:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifAhom-Regular.ttf: Noto Serif Ahom:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifYezidi-Regular.ttf: Noto Serif Yezidi:style=Regular
/usr/share/fonts/truetype/liberation/LiberationMono-Bold.ttf: Liberation Mono:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifBengali-Bold.ttf: Noto Serif Bengali:style=Bold
/usr/share/fonts/truetype/noto/NotoSansTifinaghTawellemmet-Regular.ttf: Noto Sans Tifinagh Tawellemmet:style=Regular
/usr/share/fonts/truetype/noto/NotoSansBamum-Bold.ttf: Noto Sans Bamum:style=Bold
/usr/share/fonts/truetype/noto/NotoSansRunic-Regular.ttf: Noto Sans Runic:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Medium
/usr/share/fonts/truetype/noto/NotoSerifKhojki-Regular.ttf: Noto Serif Khojki:style=Regular
/usr/share/fonts/truetype/noto/NotoSansNewTaiLue-Regular.ttf: Noto Sans New Tai Lue:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Condensed Thin
/usr/share/fonts/truetype/ubuntu/UbuntuMono[wght].ttf: Ubuntu Mono:style=Regular
/usr/share/fonts/truetype/noto/NotoKufiArabic-Regular.ttf: Noto Kufi Arabic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansOldSogdian-Regular.ttf: Noto Sans Old Sogdian:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Light
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Medium
/usr/share/fonts/truetype/noto/NotoSerifGujarati-Bold.ttf: Noto Serif Gujarati:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Extra Bold Italic
/usr/share/fonts/truetype/noto/NotoSerifArmenian-Regular.ttf: Noto Serif Armenian:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifDisplay-Regular.ttf: Noto Serif Display:style=Regular
/usr/share/fonts/truetype/liberation/LiberationSansNarrow-Regular.ttf: Liberation Sans Narrow:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCanadianAboriginal-Regular.ttf: Noto Sans Canadian Aboriginal,Noto Sans CanAborig:style=Regular
/usr/share/fonts/truetype/noto/NotoSansBalinese-Regular.ttf: Noto Sans Balinese:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLisu-Bold.ttf: Noto Sans Lisu:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=ExtraLight
/usr/share/fonts/truetype/noto/NotoSans-Bold.ttf: Noto Sans:style=Bold
/usr/share/fonts/truetype/noto/NotoSansTifinaghAir-Regular.ttf: Noto Sans Tifinagh Air:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuMono-Italic[wght].ttf: Ubuntu Mono:style=Medium Italic
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed SemiBold Italic
/usr/share/fonts/truetype/noto/NotoSansBhaiksuki-Regular.ttf: Noto Sans Bhaiksuki:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifKhmer-Regular.ttf: Noto Serif Khmer:style=Regular
/usr/share/fonts/truetype/noto/NotoSansJavanese-Regular.ttf: Noto Sans Javanese:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifMalayalam-Regular.ttf: Noto Serif Malayalam:style=Regular
/usr/share/fonts/truetype/noto/NotoSansDisplay-Italic.ttf: Noto Sans Display:style=Italic
/usr/share/fonts/truetype/noto/NotoSansBalinese-Bold.ttf: Noto Sans Balinese:style=Bold
/usr/share/fonts/truetype/noto/NotoSansLinearB-Regular.ttf: Noto Sans Linear B:style=Regular
/usr/share/fonts/truetype/noto/NotoSansKannada-Bold.ttf: Noto Sans Kannada:style=Bold
/usr/share/fonts/truetype/noto/NotoSansLycian-Regular.ttf: Noto Sans Lycian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansThai-Bold.ttf: Noto Sans Thai:style=Bold
/usr/share/fonts/truetype/noto/NotoSansShavian-Regular.ttf: Noto Sans Shavian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansBengali-Bold.ttf: Noto Sans Bengali:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=SemiBold
/usr/share/fonts/truetype/noto/NotoSansKhudawadi-Regular.ttf: Noto Sans Khudawadi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansYi-Regular.ttf: Noto Sans Yi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLinearA-Regular.ttf: Noto Sans Linear A:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Condensed Bold Italic
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=ExtraBold Italic
/usr/share/fonts/truetype/noto/NotoSansOlChiki-Regular.ttf: Noto Sans Ol Chiki:style=Regular
/usr/share/fonts/truetype/noto/NotoSansInscriptionalPahlavi-Regular.ttf: Noto Sans Inscriptional Pahlavi,Noto Sans InsPahlavi:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifDogra-Regular.ttf: Noto Serif Dogra:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLydian-Regular.ttf: Noto Sans Lydian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTagalog-Regular.ttf: Noto Sans Tagalog:style=Regular
/usr/share/fonts/truetype/noto/NotoSansOsmanya-Regular.ttf: Noto Sans Osmanya:style=Regular
/usr/share/fonts/truetype/noto/NotoSansHanunoo-Regular.ttf: Noto Sans Hanunoo:style=Regular
/usr/share/fonts/truetype/noto/NotoSansBamum-Regular.ttf: Noto Sans Bamum:style=Regular
/usr/share/fonts/truetype/noto/NotoSansDevanagari-Bold.ttf: Noto Sans Devanagari:style=Bold
/usr/share/fonts/truetype/noto/NotoSansMeeteiMayek-Bold.ttf: Noto Sans Meetei Mayek:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifGrantha-Regular.ttf: Noto Serif Grantha:style=Regular
/usr/share/fonts/truetype/dejavu/DejaVuSansMono-Oblique.ttf: DejaVu Sans Mono:style=Oblique
/usr/share/fonts/truetype/noto/NotoSansEthiopic-Regular.ttf: Noto Sans Ethiopic:style=Regular
/usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf: DejaVu Sans:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed Medium
/usr/share/fonts/truetype/noto/NotoSansOldSouthArabian-Regular.ttf: Noto Sans Old South Arabian,Noto Sans OldSouArab:style=Regular
/usr/share/fonts/truetype/noto/NotoSansOriya-Bold.ttf: Noto Sans Oriya:style=Bold
/usr/share/fonts/truetype/noto/NotoSansElbasan-Regular.ttf: Noto Sans Elbasan:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifMyanmar-Bold.ttf: Noto Serif Myanmar:style=Bold
/usr/share/fonts/truetype/noto/NotoSansGeorgian-Regular.ttf: Noto Sans Georgian:style=Regular
/usr/share/fonts/truetype/liberation/LiberationSerif-Bold.ttf: Liberation Serif:style=Bold
/usr/share/fonts/truetype/dejavu/DejaVuSansMono-BoldOblique.ttf: DejaVu Sans Mono:style=Bold Oblique
/usr/share/fonts/truetype/ubuntu/UbuntuMono[wght].ttf: Ubuntu Mono:style=Medium
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed ExtraBold
/usr/share/fonts/truetype/noto/NotoSerifTangut-Regular.ttf: Noto Serif Tangut:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuMono-Italic[wght].ttf: Ubuntu Mono:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSansTifinaghAdrar-Regular.ttf: Noto Sans Tifinagh Adrar:style=Regular
/usr/share/fonts/truetype/noto/NotoSansGrantha-Regular.ttf: Noto Sans Grantha:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono-Italic[wght].ttf: Ubuntu Sans Mono:style=SemiBold Italic
/usr/share/fonts/truetype/noto/NotoSansBassaVah-Regular.ttf: Noto Sans Bassa Vah:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifEthiopic-Regular.ttf: Noto Serif Ethiopic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansGurmukhi-Regular.ttf: Noto Sans Gurmukhi:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifSinhala-Bold.ttf: Noto Serif Sinhala:style=Bold
/usr/share/fonts/truetype/liberation/LiberationMono-Regular.ttf: Liberation Mono:style=Regular
/usr/share/fonts/truetype/noto/NotoSans-Italic.ttf: Noto Sans:style=Italic
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Condensed Medium
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=Thin
/usr/share/fonts/truetype/noto/NotoSansKharoshthi-Regular.ttf: Noto Sans Kharoshthi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansArmenian-Regular.ttf: Noto Sans Armenian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansRejang-Regular.ttf: Noto Sans Rejang:style=Regular
/usr/share/fonts/truetype/noto/NotoSansJavanese-Bold.ttf: Noto Sans Javanese:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed Italic
/usr/share/fonts/truetype/noto/NotoSansMedefaidrin-Bold.ttf: Noto Sans Medefaidrin:style=Bold
/usr/share/fonts/truetype/noto/NotoSansMedefaidrin-Regular.ttf: Noto Sans Medefaidrin:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMeeteiMayek-Regular.ttf: Noto Sans Meetei Mayek:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono-Italic[wght].ttf: Ubuntu Sans Mono:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSerifNyiakengPuachueHmong-Bold.ttf: Noto Serif Hmong Nyiakeng:style=Bold
/usr/share/fonts/truetype/liberation/LiberationSans-Italic.ttf: Liberation Sans:style=Italic
/usr/share/fonts/truetype/noto/NotoSerif-Regular.ttf: Noto Serif:style=Regular
/usr/share/fonts/truetype/noto/NotoSansNushu-Regular.ttf: Noto Sans Nushu:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed Light Italic
/usr/share/fonts/truetype/noto/NotoSerifDevanagari-Regular.ttf: Noto Serif Devanagari:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTaiViet-Regular.ttf: Noto Sans Tai Viet:style=Regular
/usr/share/fonts/truetype/noto/NotoSansDuployan-Regular.ttf: Noto Sans Duployan:style=Regular
/usr/share/fonts/truetype/noto/NotoSansBuhid-Regular.ttf: Noto Sans Buhid:style=Regular
/usr/share/fonts/truetype/noto/NotoSansThaana-Bold.ttf: Noto Sans Thaana:style=Bold
/usr/share/fonts/truetype/noto/NotoSansMro-Regular.ttf: Noto Sans Mro:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTamil-Bold.ttf: Noto Sans Tamil:style=Bold
/usr/share/fonts/truetype/noto/NotoSansDisplay-Regular.ttf: Noto Sans Display:style=Regular
/usr/share/fonts/truetype/noto/NotoSansKayahLi-Bold.ttf: Noto Sans Kayah Li:style=Bold
/usr/share/fonts/truetype/noto/NotoSansNKo-Regular.ttf: Noto Sans NKo:style=Regular
/usr/share/fonts/truetype/noto/NotoSansDeseret-Regular.ttf: Noto Sans Deseret:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSundanese-Bold.ttf: Noto Sans Sundanese:style=Bold
/usr/share/fonts/truetype/noto/NotoSansAdlamUnjoined-Regular.ttf: Noto Sans Adlam Unjoined:style=Regular
/usr/share/fonts/truetype/noto/NotoSansOsage-Regular.ttf: Noto Sans Osage:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCham-Regular.ttf: Noto Sans Cham:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTifinaghAzawagh-Regular.ttf: Noto Sans Tifinagh Azawagh:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCanadianAboriginal-Bold.ttf: Noto Sans Canadian Aboriginal,Noto Sans CanAborig:style=Bold
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Medium Italic
/usr/share/fonts/truetype/liberation/LiberationSerif-BoldItalic.ttf: Liberation Serif:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSerifEthiopic-Bold.ttf: Noto Serif Ethiopic:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifTamilSlanted-Regular.ttf: Noto Serif Tamil Slanted:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLepcha-Regular.ttf: Noto Sans Lepcha:style=Regular
/usr/share/fonts/truetype/noto/NotoSansLao-Regular.ttf: Noto Sans Lao:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Thin Italic
/usr/share/fonts/truetype/noto/NotoSerif-Italic.ttf: Noto Serif:style=Italic
/usr/share/fonts/truetype/ubuntu/UbuntuMono[wght].ttf: Ubuntu Mono:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed Thin Italic
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Condensed Extra Bold Italic
/usr/share/fonts/truetype/noto/NotoSansMiao-Regular.ttf: Noto Sans Miao:style=Regular
/usr/share/fonts/truetype/noto/NotoLoopedThai-Regular.ttf: Noto Looped Thai,Noto Looped Thai Regular:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTifinaghAPT-Regular.ttf: Noto Sans Tifinagh APT:style=Regular
/usr/share/fonts/truetype/noto/NotoSansHanifiRohingya-Regular.ttf: Noto Sans Hanifi Rohingya:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifGeorgian-Regular.ttf: Noto Serif Georgian:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifDisplay-Italic.ttf: Noto Serif Display:style=Italic
/usr/share/fonts/truetype/noto/NotoSansOldTurkic-Regular.ttf: Noto Sans Old Turkic:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifLao-Bold.ttf: Noto Serif Lao:style=Bold
/usr/share/fonts/truetype/noto/NotoSansNewa-Regular.ttf: Noto Sans Newa:style=Regular
/usr/share/fonts/truetype/noto/NotoMusic-Regular.ttf: Noto Music:style=Regular
/usr/share/fonts/truetype/noto/NotoSansEgyptianHieroglyphs-Regular.ttf: Noto Sans Egyptian Hieroglyphs,Noto Sans EgyptHiero:style=Regular
/usr/share/fonts/truetype/noto/NotoSansImperialAramaic-Regular.ttf: Noto Sans Imperial Aramaic,Noto Sans ImpAramaic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansDevanagari-Regular.ttf: Noto Sans Devanagari:style=Regular
/usr/share/fonts/truetype/liberation/LiberationSansNarrow-BoldItalic.ttf: Liberation Sans Narrow:style=Bold Italic
/usr/share/fonts/truetype/dejavu/DejaVuSansMono-Bold.ttf: DejaVu Sans Mono:style=Bold
/usr/share/fonts/truetype/noto/NotoSansMath-Regular.ttf: Noto Sans Math:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Extra Bold
/usr/share/fonts/truetype/noto/NotoSansTirhuta-Regular.ttf: Noto Sans Tirhuta:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTifinaghGhat-Regular.ttf: Noto Sans Tifinagh Ghat:style=Regular
/usr/share/fonts/truetype/noto/NotoSansDisplay-BoldItalic.ttf: Noto Sans Display:style=Bold Italic
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Condensed Extra Bold
/usr/share/fonts/truetype/noto/NotoSansBuginese-Regular.ttf: Noto Sans Buginese:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMyanmar-Regular.ttf: Noto Sans Myanmar:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifKhmer-Bold.ttf: Noto Serif Khmer:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Light
/usr/share/fonts/truetype/noto/NotoSansOldItalic-Regular.ttf: Noto Sans Old Italic:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifThai-Bold.ttf: Noto Serif Thai:style=Bold
/usr/share/fonts/truetype/noto/NotoTraditionalNushu-Regular.ttf: Noto Traditional Nushu:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono-Italic[wght].ttf: Ubuntu Sans Mono:style=Medium Italic
/usr/share/fonts/truetype/noto/NotoSansMasaramGondi-Regular.ttf: Noto Sans Masaram Gondi:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifGurmukhi-Regular.ttf: Noto Serif Gurmukhi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSylotiNagri-Regular.ttf: Noto Sans Syloti Nagri:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=Medium
/usr/share/fonts/truetype/noto/NotoSansAvestan-Regular.ttf: Noto Sans Avestan:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSinhala-Regular.ttf: Noto Sans Sinhala:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Medium Italic
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Condensed Medium Italic
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=ExtraBold
/usr/share/fonts/truetype/noto/NotoSansOldPermic-Regular.ttf: Noto Sans Old Permic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansPalmyrene-Regular.ttf: Noto Sans Palmyrene:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMalayalam-Bold.ttf: Noto Sans Malayalam:style=Bold
/usr/share/fonts/truetype/noto/NotoSansSundanese-Regular.ttf: Noto Sans Sundanese:style=Regular
/usr/share/fonts/truetype/noto/NotoSansEthiopic-Bold.ttf: Noto Sans Ethiopic:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifMyanmar-Regular.ttf: Noto Serif Myanmar:style=Regular
/usr/share/fonts/truetype/noto/NotoSerif-BoldItalic.ttf: Noto Serif:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoRashiHebrew-Bold.ttf: Noto Rashi Hebrew:style=Bold
/usr/share/fonts/truetype/noto/NotoSansKhojki-Regular.ttf: Noto Sans Khojki:style=Regular
/usr/share/fonts/truetype/noto/NotoSansGurmukhi-Bold.ttf: Noto Sans Gurmukhi:style=Bold
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Condensed Light
/usr/share/fonts/truetype/liberation/LiberationMono-Italic.ttf: Liberation Mono:style=Italic
/usr/share/fonts/truetype/liberation/LiberationSans-BoldItalic.ttf: Liberation Sans:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSerifArmenian-Bold.ttf: Noto Serif Armenian:style=Bold
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Condensed Italic
/usr/share/fonts/truetype/noto/NotoNastaliqUrdu-Regular.ttf: Noto Nastaliq Urdu:style=Regular
/usr/share/fonts/truetype/noto/NotoSansBengali-Regular.ttf: Noto Sans Bengali:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSoyombo-Regular.ttf: Noto Sans Soyombo:style=Regular
/usr/share/fonts/truetype/noto/NotoSansPauCinHau-Regular.ttf: Noto Sans Pau Cin Hau:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed Regular
/usr/share/fonts/truetype/noto/NotoSansGothic-Regular.ttf: Noto Sans Gothic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSamaritan-Regular.ttf: Noto Sans Samaritan:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCoptic-Regular.ttf: Noto Sans Coptic:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed Thin
/usr/share/fonts/truetype/noto/NotoSansMalayalam-Regular.ttf: Noto Sans Malayalam:style=Regular
/usr/share/fonts/truetype/noto/NotoSansKaithi-Regular.ttf: Noto Sans Kaithi:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTagbanwa-Regular.ttf: Noto Sans Tagbanwa:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Light Italic
/usr/share/fonts/truetype/noto/NotoSansAdlam-Bold.ttf: Noto Sans Adlam:style=Bold
/usr/share/fonts/truetype/noto/NotoSansMeroitic-Regular.ttf: Noto Sans Meroitic:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=ExtraLight
/usr/share/fonts/truetype/noto/NotoSerifKannada-Regular.ttf: Noto Serif Kannada:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTifinaghAhaggar-Regular.ttf: Noto Sans Tifinagh Ahaggar:style=Regular
/usr/share/fonts/truetype/noto/NotoSansGunjalaGondi-Regular.ttf: Noto Sans Gunjala Gondi:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSansArabic-Bold.ttf: Noto Sans Arabic:style=Bold
/usr/share/fonts/truetype/noto/NotoSansKhmer-Regular.ttf: Noto Sans Khmer:style=Regular
/usr/share/fonts/truetype/liberation/LiberationSerif-Regular.ttf: Liberation Serif:style=Regular
/usr/share/fonts/truetype/noto/NotoSans-BoldItalic.ttf: Noto Sans:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSansTamilSupplement-Regular.ttf: Noto Sans Tamil Supplement:style=Regular
/usr/share/fonts/truetype/noto/NotoSansOldPersian-Regular.ttf: Noto Sans Old Persian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansAnatolianHieroglyphs-Regular.ttf: Noto Sans Anatolian Hieroglyphs,Noto Sans AnatoHiero:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSymbols2-Regular.ttf: Noto Sans Symbols2:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMono-Bold.ttf: Noto Sans Mono:style=Bold
/usr/share/fonts/truetype/noto/NotoSansManichaean-Regular.ttf: Noto Sans Manichaean:style=Regular
/usr/share/fonts/truetype/noto/NotoLoopedLao-Regular.ttf: Noto Looped Lao,Noto Looped Lao Regular:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Bold Italic
/usr/share/fonts/truetype/noto/NotoSansBatak-Regular.ttf: Noto Sans Batak:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifDisplay-Bold.ttf: Noto Serif Display:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Light Italic
/usr/share/fonts/truetype/noto/NotoSansSharada-Regular.ttf: Noto Sans Sharada:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Thin
/usr/share/fonts/truetype/noto/NotoSansTaiTham-Regular.ttf: Noto Sans Tai Tham:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuMono-Italic[wght].ttf: Ubuntu Mono:style=Italic
/usr/share/fonts/truetype/noto/NotoKufiArabic-Bold.ttf: Noto Kufi Arabic:style=Bold
/usr/share/fonts/truetype/noto/NotoSansHatran-Regular.ttf: Noto Sans Hatran:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed ExtraLight Italic
/usr/share/fonts/truetype/noto/NotoSansThaana-Regular.ttf: Noto Sans Thaana:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifNyiakengPuachueHmong-Regular.ttf: Noto Serif Hmong Nyiakeng:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMultani-Regular.ttf: Noto Sans Multani:style=Regular
/usr/share/fonts/truetype/noto/NotoSansCham-Bold.ttf: Noto Sans Cham:style=Bold
/usr/share/fonts/truetype/noto/NotoSansArabic-Regular.ttf: Noto Sans Arabic:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=SemiBold
/usr/share/fonts/truetype/noto/NotoSansDisplay-Bold.ttf: Noto Sans Display:style=Bold
/usr/share/fonts/truetype/noto/NotoSansGujarati-Regular.ttf: Noto Sans Gujarati:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed Light
/usr/share/fonts/truetype/noto/NotoSansCarian-Regular.ttf: Noto Sans Carian:style=Regular
/usr/share/fonts/truetype/noto/NotoSansKannada-Regular.ttf: Noto Sans Kannada:style=Regular
/usr/share/fonts/truetype/noto/NotoMono-Regular.ttf: Noto Mono:style=Regular
/usr/share/fonts/truetype/noto/NotoSansChakma-Regular.ttf: Noto Sans Chakma:style=Regular
/usr/share/fonts/truetype/noto/NotoSansHanifiRohingya-Bold.ttf: Noto Sans Hanifi Rohingya:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifDevanagari-Bold.ttf: Noto Serif Devanagari:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed Medium Italic
/usr/share/fonts/truetype/noto/NotoSansTaiTham-Bold.ttf: Noto Sans Tai Tham:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifGujarati-Regular.ttf: Noto Serif Gujarati:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifTibetan-Bold.ttf: Noto Serif Tibetan:style=Bold
/usr/share/fonts/truetype/noto/NotoSansZanabazarSquare-Regular.ttf: Noto Sans Zanabazar Square,Noto Sans Zanabazar:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono-Italic[wght].ttf: Ubuntu Sans Mono:style=Italic
/usr/share/fonts/truetype/noto/NotoSansCherokee-Regular.ttf: Noto Sans Cherokee:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Italic
/usr/share/fonts/truetype/noto/NotoSansBrahmi-Regular.ttf: Noto Sans Brahmi:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifGeorgian-Bold.ttf: Noto Serif Georgian:style=Bold
/usr/share/fonts/truetype/liberation/LiberationSansNarrow-Bold.ttf: Liberation Sans Narrow:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed Bold
/usr/share/fonts/truetype/noto/NotoSansSymbols-Regular.ttf: Noto Sans Symbols:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMendeKikakui-Regular.ttf: Noto Sans Mende Kikakui:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifBengali-Regular.ttf: Noto Serif Bengali:style=Regular
/usr/share/fonts/truetype/noto/NotoSansVai-Regular.ttf: Noto Sans Vai:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Condensed ExtraBold Italic
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed ExtraLight
/usr/share/fonts/truetype/noto/NotoSansLao-Bold.ttf: Noto Sans Lao:style=Bold
/usr/share/fonts/truetype/noto/NotoSansElymaic-Regular.ttf: Noto Sans Elymaic:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSinhala-Bold.ttf: Noto Sans Sinhala:style=Bold
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Condensed Thin Italic
/usr/share/fonts/truetype/noto/NotoSansSymbols-Bold.ttf: Noto Sans Symbols:style=Bold
/usr/share/fonts/truetype/liberation/LiberationSans-Bold.ttf: Liberation Sans:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifTelugu-Bold.ttf: Noto Serif Telugu:style=Bold
/usr/share/fonts/truetype/noto/NotoSansCherokee-Bold.ttf: Noto Sans Cherokee:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifTibetan-Regular.ttf: Noto Serif Tibetan:style=Regular
/usr/share/fonts/truetype/noto/NotoNaskhArabic-Regular.ttf: Noto Naskh Arabic:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Bold
/usr/share/fonts/truetype/noto/NotoSansGeorgian-Bold.ttf: Noto Sans Georgian:style=Bold
/usr/share/fonts/truetype/ubuntu/UbuntuSans[wdth,wght].ttf: Ubuntu Sans:style=Condensed SemiBold
/usr/share/fonts/truetype/noto/NotoSansTelugu-Regular.ttf: Noto Sans Telugu:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=ExtraLight Italic
/usr/share/fonts/truetype/noto/NotoSerif-Bold.ttf: Noto Serif:style=Bold
/usr/share/fonts/truetype/noto/NotoSansHebrew-Regular.ttf: Noto Sans Hebrew:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSans-Italic[wdth,wght].ttf: Ubuntu Sans:style=Thin Italic
/usr/share/fonts/truetype/noto/NotoSerifLao-Regular.ttf: Noto Serif Lao:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMandaic-Regular.ttf: Noto Sans Mandaic:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifTamilSlanted-Bold.ttf: Noto Serif Tamil Slanted:style=Bold
/usr/share/fonts/truetype/noto/NotoSansKayahLi-Regular.ttf: Noto Sans Kayah Li:style=Regular
/usr/share/fonts/truetype/noto/NotoSansMahajani-Regular.ttf: Noto Sans Mahajani:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu-Italic[wdth,wght].ttf: Ubuntu:style=Condensed Light Italic
/usr/share/fonts/truetype/noto/NotoNastaliqUrdu-Bold.ttf: Noto Nastaliq Urdu:style=Bold
/usr/share/fonts/truetype/noto/NotoSansOldHungarian-Regular.ttf: Noto Sans Old Hungarian,Noto Sans OldHung:style=Regular
/usr/share/fonts/truetype/ubuntu/UbuntuSansMono[wght].ttf: Ubuntu Sans Mono:style=Light
/usr/share/fonts/truetype/noto/NotoSerifThai-Regular.ttf: Noto Serif Thai:style=Regular
/usr/share/fonts/truetype/noto/NotoSansIndicSiyaqNumbers-Regular.ttf: Noto Sans Indic Siyaq Numbers:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifSinhala-Regular.ttf: Noto Serif Sinhala:style=Regular
/usr/share/fonts/truetype/noto/NotoSansAdlam-Regular.ttf: Noto Sans Adlam:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTifinaghSIL-Regular.ttf: Noto Sans Tifinagh SIL:style=Regular
/usr/share/fonts/truetype/noto/NotoSansSiddham-Regular.ttf: Noto Sans Siddham:style=Regular
/usr/share/fonts/truetype/noto/NotoSansOgham-Regular.ttf: Noto Sans Ogham:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifKhojki-Bold.ttf: Noto Serif Khojki:style=Bold
/usr/share/fonts/truetype/noto/NotoSansTelugu-Bold.ttf: Noto Sans Telugu:style=Bold
/usr/share/fonts/truetype/noto/NotoSansTaiLe-Regular.ttf: Noto Sans Tai Le:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Bold
/usr/share/fonts/truetype/noto/NotoSansPhagsPa-Regular.ttf: Noto Sans PhagsPa:style=Regular
/usr/share/fonts/truetype/noto/NotoSansPhoenician-Regular.ttf: Noto Sans Phoenician:style=Regular
/usr/share/fonts/truetype/dejavu/DejaVuSerif.ttf: DejaVu Serif:style=Book
/usr/share/fonts/truetype/noto/NotoSansTifinaghAgrawImazighen-Regular.ttf: Noto Sans Tifinagh Agraw Imazighen:style=Regular
/usr/share/fonts/truetype/noto/NotoSansTifinaghRhissaIxa-Regular.ttf: Noto Sans Tifinagh Rhissa Ixa:style=Regular
/usr/share/fonts/truetype/noto/NotoSans-Regular.ttf: Noto Sans:style=Regular
/usr/share/fonts/truetype/noto/NotoSansHebrew-Bold.ttf: Noto Sans Hebrew:style=Bold
/usr/share/fonts/truetype/noto/NotoSansSoraSompeng-Bold.ttf: Noto Sans Sora Sompeng:style=Bold
/usr/share/fonts/truetype/noto/NotoSansTamil-Regular.ttf: Noto Sans Tamil:style=Regular
/usr/share/fonts/truetype/noto/NotoSerifMalayalam-Bold.ttf: Noto Serif Malayalam:style=Bold
/usr/share/fonts/truetype/noto/NotoSerifKannada-Bold.ttf: Noto Serif Kannada:style=Bold
/usr/share/fonts/truetype/noto/NotoLoopedLao-Bold.ttf: Noto Looped Lao,Noto Looped Lao Bold:style=Bold
/usr/share/fonts/truetype/noto/NotoSansGlagolitic-Regular.ttf: Noto Sans Glagolitic:style=Regular
/usr/share/fonts/truetype/ubuntu/Ubuntu[wdth,wght].ttf: Ubuntu:style=Condensed Bold
/usr/share/fonts/truetype/noto/NotoSansNabataean-Regular.ttf: Noto Sans Nabataean:style=Regular
I made some changes to support fonts. Today’s build, available after 11h CEST should fix the issues reported here. The version is 9.0.26258.*
