I’m working with Rhino.Compute (tried both 8081 and 6500 port) locally, and it’d been working fine till I get this error. I got null value from jsonElement[“archive3dm”]. However, when I check the JToken it is not a null object rather all the fields have data it requires. The only odd thing I discovered is that the JToken has an extra curly bracket surrounds the data that I really need, I’m not sure if this is the reason. Please take a look at the screenshot I have attached. This error comes from the method ToObjectHelper in the GeometryEndPoint.cs from Compute.Geometry csproj.
Is this a known bug in Rhino.compute?
And this is the double curly brackets from the JToken object.
Any help is really appreciated, thanks!
