Hi everyone,
when I load a module compiled with the Rhino compiler and a human UI interface, closing this window crashes every time Rhino, which is problematic when installing at a customer.
Have you ever noticed this problem?
thank you in advance
Hi everyone,
What is the rhino compiler?
this is the rhino script compiler command.
Hi @andheum ,
could you see the problem I was talking about?
Sorry, I don’t have time to look into this.
I am not so sure whether the problem is really solved. But I’d like to share something I tried. I use metahopper and humanUI together to solve the problem.
when I compile I get an error. Error (CS1009)
I’m really looking forward to compiling the UI Humen. but I don’t think it’s real.
I confirm that I would also like to be able to compile the grasshopper definitions containing interfaces made with Human UI components. This would quickly create ergonomic plugins that are easy to deploy and use.
Hello, are there any news about compatibility of human ui when creating .rhi gh compiler??
Thank you
