A lot of times when I’m modeling something in Rhino where I use real world measurements I use a lot of triangle geometry to make reference points. Right now I do the calculations outside of Rhino and then make the triangles by hand.
It would be awesome if there is a command or plugin that would alow you to define the kind of triangle you’re building ( SSS , SAS , ASA , AAS) and then input the angles/sides to generate the triangle.
Does anything like this exist?
