I noticed that the ‘rhino command’ component of Lunchbox - causes my gh file to be unresponsive after executing the command, not being able to pan the doc or click a component. This happens with any given command. Can someone confirm this behaviour? If so, guess I’ll move to alternative solution.
I have faced the similar problem before with Lunchbox. When you click the button to execute the command, it will freeze. Now you cannot pan or zoom etc, so try clicking on the button again, even though it seems it is not clicking, now you will see that the interface is not frozen anymore. So basically the button blocks and the button unblocks the interface. It’s most probably a glitch.
