would it be possible to have a colored tabs in toolbars?
I believe that it would help to quickly and easier navigate better than reading texts on the tabs only.
Hello- For now, at the Rhino UI level, you can set the tabs to use ‘Image’ or ‘Image and Text’ in Options > Toolbar > Size and Styles. Editing the tabs properties afterwards will let you set a plain color if you do not like the icon provided. Not quite the same, but possibly a reasonable workaround.
I agree that that type of coloring could be very useful for visually organizing and quick navigation!
The default should be subtle but as extreme as we want when customized.
