I’m currently learning how to use V-Ray and could really use some help. For some reason, one of my section cuts is appearing as a dark gray box, while the others are displaying correctly.
Does anyone know what might be causing this or how to fix it?
Difficult to tell why this particular polysurface will not render properly but the others do. It would probably take more time to figure this out than just redrawing it and applying the same parameters (materials, …) you applied on the polysurfaces that work.
When you’re first starting with Rhino and V-Ray, you may encounter occasional bugs or unexpected behaviors. Learning to work around them is often the most efficient use of your time.
