So I am exporting Rhino models into another format.
I’m obtaining meshes using RhinoMeshObjects. So, whenever I explode some blocks in the model, and export it via my plugin, some of the exploded meshes do not have any material applied on them.
So does exploding a block instance change its material property?
Currently, I am using this code to get the material index (The materials themselves are being exported fine though):
int GetMaterialIndex(CRhinoDoc& doc, const CRhinoObjectMesh& object_mesh, int default_material_index)
char* name = GetNameFromONwStr(object_mesh.m_parent_object->Name());
if (name != nullptr)
::RhinoApp().Print("\nGetting the material index for object %s", name);
int material_index = -1;
int layer_index = -1;
switch (object_mesh.m_mesh_attributes.MaterialSource())
case ON::material_from_object:
::RhinoApp().Print("\nMaterial is from - OBJECT");
material_index = object_mesh.m_mesh_attributes.m_material_index;
break;
case ON::material_from_layer:
::RhinoApp().Print("\nMaterial is from - LAYER");
layer_index = object_mesh.m_mesh_attributes.m_layer_index;
material_index = doc.m_layer_table[layer_index].m_material_index;
::RhinoApp().Print("\nMaterial Index is %d", material_index);
break;
case ON::material_from_parent:
::RhinoApp().Print("\nMaterial is from - PARENT");
const CRhinoInstanceObject* iref_object = object_mesh.m_iref_object;
if (iref_object)
switch (iref_object->Attributes().MaterialSource())
material_index = iref_object->Attributes().m_material_index;
break;
layer_index = iref_object->Attributes().m_layer_index;
break;
break;
default:
::RhinoApp().Print("\n****NO MATERIAL IS FOUND FOR THIS OBJECT !!!!****");
break;
if (material_index == -1)
return default_material_index;
else
return material_index;
