I was certain this command worked previously. MakeUnique, and ResetBlockScale work, but SelSameBlocks is unknown command. Thoughts
RH 7.18
BlockTools 1.4
RH 7.18
BlockTools 1.4
I’m not familiar with this “BlockTools 1.4” plug-in.
Wim is right. It is created by ejnaren. I’ve been using it ever since I discovered it gave Rhino the “make [block] unique” feature that I use extensively in Sketchup.
Hmmm… The error description here is little to go by
I don’t really know what happens and why it has not registered or forgotten the command.
Maybe try and install it again?
It’s a simple plugin adding three commands that are really helpful working with blocks.
I have been in dialogue with Pascal on including this in Rhino as the commands are very basic:
They are hosted on GitHub:
I would love to revive the discussion to add these commands to Rhino itself!
Thanks for the response. I did remove, reinstall, etc. Did it on my old Win 10 install of Rhino, and my new install after I moved to Win 11. Pretty odd that the other commands work?
Yep, Rhino should have the commands.
Wierd.
But I can try and update rhino and try if it fails for me as well and get back to you.
Otherwise I am not really sure how to troupleshoot this for you unless you run the command in the python editor and report the errors.
Can you explain how to do that?
