Rhino BETA - OptionsImport Problem
Somehow since the last update OptionsImport doesn’t update all system settings. Aliases and keyboard shortcuts don’t update on my system.
Even when I edit them manually, for example adding manually a new alias, it is forgotten on the next start.
Does anybody has the same thing?
@Erdem What version number are you running? Could you paste the result of the _SystemInfo command here?
Probably related to this: RH-97739 All settings wiped on newest Beta. Multiple threads appearing related to settings issues.
Hello Pierre,
Here it is…
Rhino 9 SR0 2026-8-4 (Rhino 9 BETA, 9.0.26216.12303, Git hash:master @ 5ca1621d579933d7769ad5ce75f25b218981579e)
License type: Commercial, build 2026-08-04
License details: Cloud Zoo
Expires on: 2026-09-18
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9310.0
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 6-12-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\import_GHS.rhp “General Hydrostatics (GHS) Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
@Erdem Thanks, I’ve tried that same version and a few others but have not been able to reproduce the bug. I had seen some mysteriously disappearing aliases too earlier in July, but they all came back after OptionsImport of a previous settings save. New aliases also do not disappear after a restart of Rhino.
Let us know if you still see that in the latest Beta release (9.0.26223.12303), or if you have a set of reproducible steps to get some aliases to disappear after a restart or not getting imported.
With OptionsImport, are you selecting a .rhs file or a .ini file?
Not too sure about that, that seems to say only toolbar and some other UI settings are affected. The linked threads say that aliases are not affected. And I’ve told Callum about this thread so I’m sure he would have connected the dots if they needed to be connected :slight_smile:
it is an .rhs file. I exported it with the previous beta.
I tried even manually add one alias. It stays there in the active session. But as soon as I close Rhino and open a new one it is gone…
I’ll install the new one and let you know. Thanks.
  1. Reset Aliases to default.
  2. Add a new Alias of two or more characters.
  3. Close and reopen Options to confirm it is there.
  4. Close Options and run Export Options.
  5. Restart Rhino and run Import Options selecting Aliases.
  6. Open Options and find the list is shortened (although the new Alias is there).
  7. Click ‘Reset to Default’ and get back the missing Aliases but lose the new one.
It looks as though in the Export/Import process, single letter aliases are lost.
I can’t attach the .rhs file to this post but can email it to you if you want it.
HTH
Jeremy
exactly, my single letter aliases are not even imported with OptionsImport and when I manually enter, they are gone when the session is over.
The problem persists in the latest BETA (9.0.26230.12303 | 18. August 2026 | 699.7 MB).
Thanks a lot for the repro steps and continuing to try this. I’ve logged this for the developer working on Options Import/Export:
RH-97898 is fixed in Rhino BETA
Hello Brian,
Thanks for the update. The single letter aliases are now imported successfully but the F-Keys aren’t.
For example, I had set my F5 key to Zoom Selected but when I import the settings F5 functions as SelectionFilterToggle.
Good old Whack-a-mole bug fixing. I’ve reopened the ticket @Erdem, thanks for reporting :slight_smile:
:sweat_smile: sorry for making you open it again! And a big thank you!
We make the software for you, so it’s important it works for you :slight_smile:
@Erdem I can’t reproduce this. Here’s what I tried (on Windows):
  • In Options → Keyboard → F5: Set it to ! _Zoom or z
  • OptionsExport to a new .rhs file
  • OptionsImport, select the .rhs file, select shortcuts or all options
  • In Options → Keyboard: verify that F5 is still ! _Zoom or z
If you still see this in the latest Beta version, could you give me reproducible steps, or post your .rhs file here or send it in a DM if you want to keep it private?
Thank you Pierre, I sent you a DM.
