I noticed that the most recently used toolbar does not populate. It stays empty. Did something change recently with this? I have a blank toolbar where I thought I had the MRU toolbar docked.
Okay, I’ve been digging into this on my end and I discovered that it does work (kind of). It gets wiped clean when the Rhino beta is closed and reopened. This should not happen. That toolbar should be “remembered” between sessions. Also, like I’ve mentioned in the past, there should be an option so that the icons don’t move to the top when used out of the MRU toolbar.
Thanks,
Dan
both issues have been logged based on your earlier reports
Perfect. Thanks.
