I have an object on Rhino document. I import it into Grasshopper. When I delete the object in Rhino, the component in Grasshopper turns orange, stating that the referenced object cannot be found. Until this point everything is normal.
But when I undo the delete operation in Rhino, the component in Grasshopper stays orange. In other words it doesn’t realize that this object is again back in the document. I then need to import the object again back to the GH component.This was not like this before Rhino BETA.
You know, F5 refreshes everything, whereas auto detection runs the script from the point on where the undo affected and this saves time. If you have a big definition this can save time.
Anyway, I just don’t want to lose what already worked great on the previous versions. Maybe someone from McNeel can address this.
