Rhino BETA Feature: Lighting through clipping planes
When a clipping plane cuts through a model, the render preset now decides how the cut affects lighting. This applies to Rhino Render and the Raytraced viewport.
Architecture (left) and Product (right)
Architecture (top), Product (below)
How to use it?
  • Select the Product setting in the Rhino Render Advanced Settings on the Rendering panel, under Presets. Clipped geometry is removed completely, so light comes in through the cut and lights the inside.
  • Select the Architecture setting to keep the previous behaviour. Clipped geometry still blocks light, so a sectioned building is lit as if its outer walls were still there.
Switching presets updates Raytraced right away.
Try it out in Rhino BETA. Feedback and bug reports are welcome.
Thanks.
-Lars
Could this be enabled in the concept mode too?
Martin
No - we currently can’t get the SSAO skylight shadows to work with it. So it’s not going into the display. Cycles only.
  • Andy
Is it intentional that the “product” preset leaves the section empty?
If so it looks a big mistake in my opinion. As Designer I would like to see the solid part of my model (thikness) in render mode as well.
@andy ?
