Rhino BETA Feature: Knife
@xkdsofa Could you send me your display configuration, a SystemReport and maybe an export of your current display mode? Your Knife “in progress” display has sizes different from what I wanted to get and from what I see here. I’d like to fix that.
(And of course if you have comments about these little changes to the display of Knife, now is a good time to make them!)
RH-95677 is fixed in Rhino WIP
I see that this has been fixed in the latest version and done very well. Thank you to the developers for your hard work!
For me it doesn´t work in any way.
Any ideas why this could be?
can you give us some more detail?
are you using the v9 wip? if so have you updated it to the latest version?
are you using a mac or a pc?
are you using it on a subd object?
can you send a model with screen shots of the failure?
I can’t get it to work on any meshes, tried boxes, planes, different subdivions (or segments). The object will usually not want to get selected, or if it does its only with a filter for the face, and then nothing can happen anyway. (and ofc not on a normal plane etc). Tried meshplane, meshbox etc.
For subd it works fine no problem.
Anyone who has experienced the same?
Knife works on SubDs only as of early June 2026. Unfortunately, adding support for things like inserting a point in the middle of a face with Knife meant that I had to stop supporting meshes, which lack a lot of the nice topological modifications features that SubDs have, in the Rhino kernel.
There is currently no plan to support meshes again in Knife. InsertPoint on the other hand still works on meshes, or if you really need to Knife a mesh you can try converting it to a SubD first, then recover the mesh after modification with ExtractControlPolygon
ah ok thats a shame. any chance of it coming in the future? what if it just had reduced scope / some things it couldnt do?
When using Knife in a Perspective viewport, enabling Ortho (or holding Shift) constrains the direction relative to the current view rather than to world/CPlane coordinates.
Is this intentional? To me it seems like Ortho constraint should snap to world/CPlane axes, not to the camera’s current orientation — otherwise rotating the perspective camera changes which direction the cut snaps to, which feels inconsistent with how Ortho works elsewhere in Rhino.
Video attached showing the behavior.
Yes, this is intentional. Knife is entirely based on projecting a polyline drawn on the screen plane, in the direction of the current view. That’s also why it will cut using a projection to a point in a perspective view, and a parallel projection in an orthographic view: this way the cut points always lie exactly behind the poyline that was drawn on screen space.
If you rotate the view during a Knife operation, the cut points will temporarily be kept where they were last found using the projection with the previous view direction. As soon as you select a new Knife point, all the cuts will be recomputed with the new view direction. Early testers told me that this behavior is fine, and I prefer this to updating the cut points continuously as you rotate the view, but I’m open to changing this if needed.
This behavior with ortho active is definitely different from other Rhino commands, but that’s because very few other Rhino commands interact with the screen plane. The new Markup commands work in screen plane and also use ortho snaps in the screen plane.
@Viterkim
See above:
InsertPoint is currently the “reduced scope” version of Knife that works on meshes. What do you have in mind that would make InsertPoint better for meshes, without requiring all the features of Knife?
Hmm i guess the only luxury things would be like, starting the cut from somewhere else as a snap. But i get how that could be difficult because then you rely on viewpoint projection or something.
And then cutting through multiple faces on top of each other.
I think even with restrictions like it only working on full planar stuff it could still be cool.
