For once I’m with @encephalon on this - I don’t recall many if any requests for this here publicly at least…
Back in Rhino 2, it was possible to individually custom color the backgrounds of the icons. I actually did the same thing, I used one color for curves, a second color for surfaces, a third for transformations etc. I probably also had 6 colors or so, it’s been a long time… In Rhino 3 this possibility was removed because the backgrounds were made ‘transparent’ and could be modified globally - and there was - popular at the time - a possiblity to use a two-color gradient which made the buttons look pseudo-3D. I’m pretty sure the default setup was this way with a gradient gray.
I was disappointed at first when Rhino 3 came out because I thought I would miss my color coding. After awhile I realized that the colors actually didn’t matter, it was the geographical placement of the icons that was key. Since then, I have never re-felt the need for color coding of the icons themselves - except…
OTOH, I have extensively modified quite a number of the icons because they were not clear enough to me. I continue to do that today. For example selection for me is always yellow. The default curve selection icons have just these little corners.
OK, I added texts as well because this particulat toolbar functions as a popup menu, but the idea for the images was that the objects appeared highlighted as if selected.
A way for the user to swap out the icons against the old ones or even custom ones would probably help to satisfy those who don’t like the new colors/icons.
Then Rhino would need a way to easily and reliably swap all icons and back. Rhino icon packs on food-for-rhino could be a thing.
I personally wouldn’t need this. The dev team needs to think about where to allocate resources to. I don’t know if this would be a complex undertaking but it would very likely be a way to make more people find peace with the Rhino icons.
Just played a bit in Paint NET with the lower image to make the upper one. Not optimized due to the low resolution of the original image, but still gives a clear idea about the low contrast and limited colour range that make the readability of the icons much worse in Rhino 9.
how do you fair reading a book then? does every word have to be a different colour to differentiate them better? or maybe every letter? all a gray, white or black mess if you see it like that.
i never claimed they are perfect, there is room to improve but still way better than the mess we have now. a tendency to calm things down rather than blowing it all up something worth noting. there is also a reason why other apps have the same ideas, maybe some dont like it but it sure makes sense for many others.
a piano has 88 keys which all look the same besides the black and white differentiation and still is a joy to play. but if you have to practice so intensely just to be able to play at all, there might be something wrong.
if you are in such a hurry you should avoid the icons all together. i also have shortcuts for most of what i need. still i find the wip9 an unsettling noise with all that excessive colour explosions. you may disagree, maybe 2-3 people more, but there are sure some that dont. i dont see a valid poll that tells as an honest ratio so far.
I don’t know if you have noticed before but piano != rhino.
Piano (and most intstruments) you play without looking at the thing (apart from during the learning process). You learn the physical geometry and rely on haptics. Something you cannot do with a computer at this point in time. Just like a good typist - once you get the hang of it you will hardly ever look at the keys anymore if ever.
That said there are color coded piano keys - or at least stickers to do so. Lots of color in that ( see for instance piano color coded at DuckDuckGo ). You’ll find there are even scores printed in matching fancy colors.
Also, look up the lumatone. Very colorful keys (and interesting geometry, has been on my wishlist for years).
Also, book != rhino.
A book (fiction at least), and music score you read in one direction, you do not go about searching on pages for a specific part then to jump around and go do something else. You don’t need the color seperation.
Although for music I can imagine that certain parts could definitely do with color, like repetition marks or doing dal segno al coda, where you actually do jump around (but still in mostly a linear fashion). When I played in a symphony orchestra and in different ensembles (guitar, oboe) I would use color to make markings to help guide the eye.
And for books color might be interesting for demarcation of chapters perhaps. In certain books you’ll find that signalling different types of content is done with typesetting - size, typeface, bold, cursive. Since you still read linearly these methods are pretty much enough to differentiate. Want to skip to the next chapter? Page through the book until you find the next clearly demarcated bit (bigger text, heavier setting).
Anyway, print is just the two colors mostly because of costs. Where there is budget for color you definitely see color coding, where color is used to help guide the eye, mark sections of pages, books so you can, at a glance, see where different types of information lives (school books, reference material).
Even more so, people apparently annotate books using highlight markers, and make them very colorful (color coded pages in books at DuckDuckGo). Why? Because in this case you’re not just reading linearly, you’re searching for something. And the colors help guide your eye. (I personally don’t mark up actual books, nor score books - only ever paper copies of the parts I am using - but I do mark up stuff with color, because you know, it helps the eye).
The same with a GUI. I want the color to guide my eye. Do I need some surfacing? Look for the blue stuff. Do I need to tinker with rendering? Look for the orange stuff.
when you look for some info in a book for instance you quickly scan through the pages looking for the keywords that you know by shape, it saves time from having to read the entire book when one only needs that one section for now. i at least can do that because i know the shape of the word and can quickly identify it within all the other words, that is something not everyone does maybe?
in Rhino we have tabs now (which i would personally also like to deactivate) which can help for a quick reference in which ballpark to look for, be it a little symbol or some text
these icons below for example are quite ok in my eyes. they are more or less quickly identifiable, it does not need an arbitrary selection of colours to make them anyhow louder.
and once you accommodate yourself with the icons and position just like a pianist you will quickly navigate to the area and click on that icon. i also needed some confusion time till i got used to the monochromatic icons in mac, but i seriously appreciated how calm the entire screen was, maybe indeed using Rhino like a pianist in the end.
(the icon size was set to 32 because I have 4K monitors)
Note that the image parts of the WIP icons are about the same size - with a couple of exceptions - but the surrounds have gotten a bit bigger, so that the same amount of button rows take up more space vertically - I think about 2 px per row. Not a really big deal, but I noticed it because my laptop vertical space is more limited than my desktop, so my custom WIP arrangement doesn’t quite fit where the same one did in V8.
Here, one can more easily see some of the contrast loss in the WIP, mostly due to the lighter colors and the elimination of the full black borders in various areas. You are probably going to need to download and look at the image in full rez to fully appreciate the difference.
As mentioned before, most males see a lower contrast than most females, no matter if they are colour blind or not. Also, there are studies that confirm that a 20-year old human (especially if it’s a female) has twice as strong contrast vision compared to a 65-old human. Even if one had a great vision in his or her young age, the contrast sensitivity weakens as the person gets older. Combine that with the fact that most adults also start to suffer from myopia (inability to see distant object as sharp as before), and the general picture is not looking great. These factors together must be taken into consideration when decisions for the UI are made.
I also wonder why there is some inconsistency with the new icons regarding their isocurves. Some icons representing surfaces have isocurves for no reason (like “Surface from 4 points”, where the accent must be on the points rather than the isocurves), others don’t (like the new icon for “Boolean union”).
Here is the original V9 icon on the left side (low contrast, blueish border and isocurves), and my proposal on the right side (higher contrast, black border, removed isocurves).
