Rhino BETA Feature: Direct3D Display
Personal benchmarks on a very heavy assembly imported from Solidworks, using TestMaxSpeed command. (Btw, Rhino 8 failed to import the SLDASM file, but Rhino 9 succeed).
Specs:
Intel Ultra 9 185H
64 GB LPDDR5
Nvidia GeForce RTX 4070 Laptop 8 GB (Driver Date: 5-3-2026 Driver Version: 32.0.15.9647)
Rhino 8.
OpenGL only.
Antialiasing 8x, GPU Tessellation ON, Level - Max OpenGL Available.
Shaded mode ~45 fps.
Wireframe mode ~36 fps.
Rhino 9.
OpenGL.
Shaded mode ~19 fps.
Wireframe mode ~70 fps. (strangely)
Direct3D.
Shaded mode ~20 fps.
Wireframe mode ~31 fps.
So in general, Rhino 9 feels slower, especially on Direct3D.
Out of curiosity I changed the aliasing in Rhino 9 Direct3D to None - did absolutely nothing.
In all versions, mesh setting were set to default “Jagged and faster”.
I will update my GPU drivers and report here later.
UPD: latest GPU drivers made it slightly worse (RH9, Direct3D).
UPD 2:
Tested on Rhino 7 as well. Spoiler: what a performance gap between Rhino 7 and Rhino 8/9! :frowning:
OpenGL.
Shaded mode ~90 fps.
Wireframe mode ~110 fps.
Hi Kirill -
Without a 3dm file, it’s hard to tell, but this is likely on the list as RH-98352 Curve redraw is slower than in Rhino 7
Hi Wim,
Thanks for the reply. Unfortunately the model is a production/NDA piece. It consists of about 2600 polysurfaces.
I updated my previous post and added Rhino 7 to the benchmark. Sadly, Rhino 7 is ~3-5 times faster than Rhino 8 or Rhino 9. Huge gap in performance.
Hi, and thanks again for the work that has already gone into improving Direct3D point-cloud performance.
I did some further testing with the latest Rhino 9 Beta (9.0.26251) on a fairly large point-cloud dataset. The model originated from an E57 containing 370 individual scans, and the resulting 3DM contains approximately 142.1 million points in total.
I used two camera positions and ran TestMaxSpeed three times for each configuration.
Wide view
  • Rhino 8 OpenGL: 17.44 / 17.39 / 17.30 → avg. 17.38 fps
  • Rhino 9 OpenGL: 17.35 / 17.25 / 17.25 → avg. 17.28 fps
  • Rhino 9 Direct3D: 7.49 / 7.49 / 7.48 → avg. 7.49 fps
Zoomed-in view, with only a small portion of the cloud visible
  • Rhino 8 OpenGL: 55.65 / 55.65 / 56.12 → avg. 55.81 fps
  • Rhino 9 OpenGL: 56.63 / 57.64 / 57.14 → avg. 57.14 fps
  • Rhino 9 Direct3D: 12.90 / 12.90 / 12.85 → avg. 12.88 fps
Rhino 8 and Rhino 9 OpenGL scale almost identically when zooming into a small part of the cloud, improving by roughly 3.2–3.3×. Direct3D improves only 1.72×.
This makes me wonder whether the current Direct3D point-cloud path is getting substantially less benefit from visibility/frustum culling, or from whatever view-dependent optimization is used by the OpenGL path.
Thanks again — I hope these numbers are useful.
@Matteo_Falduto I’ve been focusing on display optimizations over the last couple weeks and am still working on them. I completely changed how point clouds are drawn with Direct3D. Clouds with transparent colors haven’t changed, but other types of clouds will hopefully be much faster now. It would be interesting to see what your results are like with the beta that was released today.
I should mention in general there have been a ton of optimizations made in the last two weeks. If you have a model that you feel is still slow after using today’s beta, I would love to know about it.
Is this normal?
no geometry on the screen. Just native display.
Absolutely not normal at all. Please run SystemInfo and send me the results. I currently have no idea what could be causing that.
Can I send it via email please
Thanks. Just sent it.
Retinal software detachment
I think we figured out what was happening. There was a case where if a bitmap were set for the background in a display mode and that bitmap didn’t exist anymore the display would never be properly cleared between frames. This will be fixed in the next beta
RH-99625 is fixed in Rhino BETA
Thank you, Steve and Jeff, for your prompt assistance.
@stevebaer this still seems to be the case in the latest build with GhPython (top: OpenGL, bottom: Direct3D):
SystemInfo
Rhino 9 SR0 2026-10-20 (Rhino 9 BETA, 9.0.26293.12303, Git hash:master @ 3225ee2553a4565e4ed5ef04ee64d6d334601ed4)
License type: Commercial, build 2026-10-20
License details: Cloud Zoo
Expires on: 2026-12-04
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET Framework 4.8.9363.0
Hybrid graphics configuration using OpenGL
Primary display: Intel(R) Arc™ Pro 140T GPU (16GB) (Intel) Memory: 2GB, Driver date: 4-16-2026 (M-D-Y).
Primary OpenGL: NVIDIA RTX PRO 2000 Blackwell Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-3-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 596.98
- Laptop’s primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-3-2026
Driver Version: 32.0.15.9698
Z-Buffer depth: 24 bits
Total Video Memory: 8151 MB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
DrawMeshShaded_GhPython_00.gh (17.6 KB)
Looks like some kind of lighting issue… It works in Rendered mode… I’ll get this tuned up.
Thanks,
-Jeff
RH-98334 is fixed in Rhino 9 Service Release 1
