Rhino BETA Feature: BlockEdit
The Rhino BETA includes some long-overdue improvements and fixes to the block editing command, BlockEdit.
What’s new
Summary of Improvements
Refreshed UI — The BlockEdit panel now matches the look of Rhino’s other panels, and a new Cancel button makes it clearer how to end a session without saving.
Toggle between locking and hiding non-block objects — While editing a block, you can switch between locking and hiding the surrounding objects, making it easier to work in busy scenes.
Double-click a sub-block to edit it — During a block editing session, double-click a sub-block in the model to make it the active editing block. Double-clicking elsewhere in the viewport steps back up to the parent of the block you’re editing; if you’re already editing the top-level block, it finishes the session.
Exit from the command line — Run
_-BlockEditand choose either theSaveorCancelcommand-line option to end the current session. -
Edit non-uniformly scaled blocks — You can now select a non-uniformly scaled block instance for editing.
Bug fixes
Fewer damaged files — We traced the “BlockEdit has trashed my file” issue to saving a document while a block editing session was still in progress. Saving mid-session is allowed, but in some cases information vital to the session was being lost. BlockEdit now validates the state of the document before saving any changes.
macOS multi-monitor fix — The BlockEdit UI no longer disappears when dragged to a second monitor on macOS.
Block attribute order preserved — BlockEdit was reversing the order of block attributes; it now keeps them in their original order.
How to use the BlockEdit improvements
Download the Rhino BETA and try it out. Open a file that uses blocks and give the new BlockEdit a try.
Try it
- Download the Rhino BETA .
- Download and open file: Try-It BlockEdit.3dm (2.1 MB)
- In the Top viewport, double click on the block Faucet Assembly.
- From the Block Editor dialog, pick the lock icon in the toolbar. It will change to a blue light bulb.
- Make the Perspective viewport active.
- Pick the Lever Cold\Controls Cold nested or sub block.
- Using the gumball rotate 45 degrees.
- Pick the nested block Lever Hot\Controls Hot.
- Using the gumball rotate 45 degrees with the gumball’s blue arc or rotate widget.
- Double-click on the Rhino viewport twice to exit the BlockEdit command.
- Using Gumball stretch the faucet in the x direction, so that the faucet is distorted like this.
- Double-click on the block Faucet Assembly to open the BlockEdit dialog.
- Pick on nested block Spout Faucet.
- Sub-object select the edge curve on the polysuface at the end of the spout with Shift + Control + Pick.
- Using Gumball, move the curve in the Z direction -.5 units.
- Use the BlockResetScale command to return the Faucet Assembly block to uniform scaling.
We’d love to hear your feedback. Let us know what feels useful, what works well, and where you think the feature could be improved.
Sincerely,
Mary Ann Fugier
