Rhino Beta "Cancel All" command causes a freeze of a few seconds
A freeze lasting several seconds occurs when using the RhinoBeta “Cancel All” right-click command.
Depending on the immediately preceding command, the freeze can last for tens of seconds.
This issue appears to have started occurring after installing a version two or three releases prior to the current version (rhino_9.0.26195.12303).
hi @mk_onoe
pls run _SystemInfo in Rhino and post back the results.
Hello, Gijs de Zwart.
Thank you for the prompt reply. I have provided the details of my SystemInfo below.
@mk_onoe I think you forgot something…
The contents of SystemInfo had disappeared.
I have listed the details below again.
Rhino 9 SR0 2026-7-14 (Rhino 9 BETA, 9.0.26195.12303, Git hash:master @ e65c4e97d90a610a755e1fa38d13856483719a8c)
License type: Commercial, build 2026-07-14
License details: Cloud Zoo
Expires on: 2026-08-28
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.2
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 5060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-13-2026 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 3-3-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\mk-on\AppData\Roaming\McNeel\Rhinoceros\9.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.2.0.0\KeyShot10RhinoPlugin\Rhino 7\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.2.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp "SectionTools
That is all. Thank you for your consideration.
Can you run PluginManager and disable KeyShot, restart Rhino and see if the problem persists?
Can you repeat this right away after starting Rhino, or is it model-specific?
If this is more severe with some commands than others, it would be good to list those.
I tried disabling several plugins, such as “KeyShot,” but the issue persisted.
I installed the latest version (rhino_9.0.26202.12303), but the same problem occurs.
When I launch a fresh instance of “Rhino 9 Beta” and immediately run the “Cancel All” command,
the application freezes for a few seconds after repeating the cancel operation a few times.
It also frequently freezes for a few seconds when using “Cancel All” during actual work.
May I upload a four-minute screen recording of this behavior here?
yes that might be helpful, because I don’t see any issues running Cancel All
It sometimes freezes for several tens of seconds.
@mk_onoe can you run _OptionsExport and send the resulting file to me?
I got it.
This is an option file.
(Attachment Settings_9_win.rhs is missing)
Settings_9_win.zip (2.4 MB)
