Rhino 9 WIP (9.0.26160) is now available for Windows and Mac
Bugs Fixed:
- Audit3dmFile:
- BlockEdit:
- Display: Direct3D: Round line cap is not displayed properly… (RH-95864)
- FilletSrf: commands: inherit base object properties when joined (RH-93793)
- GetPointProxy: Circle: FitPoints should accept SubD vertices (RH-95840)
- Grasshopper 2: Paste components doesn't record undo (RH-68155)
- Gumball: UVN gumball should create U and V alignment for SubD vertices if possible (RH-91153)
- No Subsystem: Material preview noisy in floating editor. (RH-85883)
- Rendering: Materials: PBR displacement is seen in Shaded modes (RH-87743)
- Section Style: Print Width "Enter" issue (RH-96015)
- Section Tools: ClippingDrawing undo/redo issues (RH-76998)
Cosmetics:
- Audit3dmFile: FileNavigator shows awkward (Hidden) (Locked) suffix (RH-96076)
- Toolbar (New): Remove unnecessary shortcuts from macros (RH-95280)
Crashes Fixed:
- Patch: Repeatable random crashes (RH-96117)
- Toolbar (New): System.InvalidOperationException: Cannot set Visibility or call Show, ShowDialog, or WindowInteropHelper.EnsureHandle after a Window has closed. (RH-95656)
Documentation:
- Documentation:
- No Subsystem: Prototype: Developers – Display: Concept Display (RH-95904)
Enhancements:
- Audit3dmFile:
- MouseOver in TreeMap to show information about a given object (RH-96034)
- What to do with Render Content? (RH-96143)
- When viewing expanded section in TreeMap, grey out FileNavigator entries not shown (RH-95995)
- Invalid objects do not appear in Issues report in Audit Summary Tab (RH-95994)
- Provide Legend to better understand colors and symbols used (RH-95997)
- FilletEdge: Replace (untrimmed) planar singular surfaces with trimmed planar surfaces (RH-88369)
- Grasshopper 2: Setting a specific value on a number slider (RH-81216)
- Inset: PushPull: Improved merging of coplanar faces in result objects (RH-91165)
- Section Style: Allows using built-in linetypes (RH-91355)
- ShowDir: Option to set the uv indicators size (RH-90676)
- Text: Resize text in the editor with mouse wheel (RH-37410)
- TextObject: bigger preview (RH-69555)
Features Added:
- FilletEdge: Added History support and DeleteInput option (RH-94007)
- IsolateToViewports:
UI Change:
- ArrayCrv (New): Default alignment inconsistent (RH-96066)
- Section Style: Changed edge thickness from 3 to 2 (RH-96075)
Usability Problems Fixed:
- ArrayCrv (New): Array Curve needs cancellation support (RH-95171)
- Audit3dmFile: File navigator is now aware of object's locked and hidden states (RH-95967)
- Modeling Aids: Simplify Crosshair Cursor (RH-96037)
- ScriptEditor: Python 3 binds Grasshopper namespace in both Grasshopper.dll and Grasshopper2.dll (RH-76310)
Mac-Only Changes
Bugs Fixed:
- Display: Incorrect Section Border Width (RH-95643)
- FileExplorer: File Explorer: slow refresh (RH-94568)
Features Added:
- UI Cleanup: macOS Liquid Glass Support (RH-90326)
Windows-Only Changes
Bugs Fixed:
- Display: Direct3D: Wallpaper with transparency loads/looks incorrectly (RH-96038)
- DotNET: Removed .NET 8/9 options from SetDotNetRuntime (RH-95468)
- Panels: Display: Button Doesn't Open Rhino Options in German (RH-96126)
- Toolbar (New): "default.rui saved successfully" popup is hidden behind main dialog on Windows (RH-95844)
- UI Appearance: Pixel alignment on Windows (RH-86236)
UI Change:
- Grasshopper: Windows Dark Mode (RH-87713)
