Rhino BETA Available Now!
Rhino 9 WIP (9.0.25294) is now available for Windows and Mac
Bugs Fixed:
  • CommandPrompt (Eto): Search command UI no longer docked after update (RH-89928)
  • Display: Per-Viewport Visibility: RhinoCommon Access (RH-89977)
  • Display: Direct3D:
  • Drag Settings: Soft Transform not working with cage without captive object (RH-89750)
  • Gumball: Direction of approach to ctrl pt changes alignment of GB (RH-89544)
  • GumballAlignment: Handles don't line up with UVN (RH-89370)
  • IsolateToViewport: Objects invisible in other viewports display when dragging (RH-89943)
  • Markup:
  • Panels: NamedView: No scroll bar in Named View panel (RH-90023)
  • Rendering: Texture Mapping: Texture mapping rotation spinner captures too many undo markers (RH-89798)
  • SDK: RhinoCommon: Squish: unable to obtain the correct result (RH-89644)
  • Selection: Create a SelIsolated command (RH-89938)
  • ShowEnds: "Zoom" button missing behavior (RH-90021)
  • SoftTransform:
    • Shouldn’t draw meshes in wireframe mode (RH-89453)
    • Drag Settings: Falloff radius at 0 shows black shade (RH-89676)
    • Allow sphere select for SoftTransform radius (RH-89483)
  • Zebra: cannot change all colors (RH-89127)
Enhancements:
  • ClippingDrawings:
    • Add Points Layer Under Section (RH-90001)
    • ClippingDrawings - Output Separate Boundary Curve (RH-89858)
  • EvaluatePt: Added OmitZeroZCoordinate option when Label=On (RH-88521)
  • Isolate: oViewport: Allow Enter for Active Viewport (RH-89954)
  • Section Tools: ClippingDrawings: Add draworder to output (RH-77443)
  • Zebra: Added static X, Y, Z buttons (RH-89997)
Features Added:
  • Display: IsolateFromViewport (RH-89874)
  • Section Tools: Add tangent edges (RH-78044)
SDK Enhancement:
  • SDK: Added double-click support to .NET UI objects (RH-89970)
UI Change:
  • Markup: Default line width should be thinner (RH-89932)
Mac-Only Changes
Bugs Fixed:
  • Emap: Hidden image import dialog locks Rhino app (RH-89988)
  • Grasshopper: Zoom and UI issues on Mac (RH-89941)
  • UI Appearance: Slider brings focus back to Rhino on Mac (RH-89924)
Regressions Fixed:
  • File IO: PDF File Read Error (RH-87627)
