Rhino beta - AI panel goes white
I try to drag and drop two images in the AI panel but i see it going white and i cannot drop anymore.
Sometimes it goes white when i switch from rhino to some other app on my desktop.
Can you please check this behaviour and fix it,
thank you
Here i added 3 images with instructions to create a python script to place circles based on the RGB, which succeeded, i then added an addition photo with no issues.
Have you been able to repeat this on a fresh instance of Rhino? Does simply drag drop do it or do you have to be in an ongoing conversation?
How big are your photos? Largest i dragged was 6.6 mb
Lets see your SystemInfo again, since you’ve updated video drivers since your last report.
@Japhy , it doesn’t happen because of the images, it happens because i switch from Rhino to windows explorer, to select them.
If i have the AI panel open and i switch from Rhino to another app, the panel will go white in Rhino. (or, it will just disappear, making drag and drop impossible either way)
And i have the panel floating not docked
Rhino 9 SR0 2026-9-29 (Rhino 9 BETA, 9.0.26272.12303, Git hash:master @ b5f5102690615c89acabfc68e24eae200f3d735b)
License type: Commercial, build 2026-09-29
License details: Cloud Zoo
Expires on: 2026-11-13
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 10.0.8
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
Hybrid graphics configuration using DirectX
  Primary display: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-4-2026 (M-D-Y).
        - Secondary monitor is laptop's integrated screen or built-in port
Secondary graphics devices.
  AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 8-13-2024 (M-D-Y).
    > Integrated accelerated graphics device with 5 adapter port(s)
        - Windows Main Display is laptop's integrated screen or built-in port
DirectX Settings
  Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
  C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp	"Commands"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp	"RhinoAI"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp	"3DxRhino.9"
  C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp	"UpdatesAndStatistics"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp	"MeshCommands"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	9.0.26272.12303
  C:\Users\bogda\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp	"PanelingTools"
  C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp	"SectionTools"
