Hi, just downloaded the latest wip and on startup I get this “Done installing plug-ins” dialog.
Though this is great I would prefer if you asked me what plug-ins I would like to install on the WIP.
Does that make sense? I also see that I can prevent plugins from loading, but I can not uninstall them. I think that would make sense too.
So the only way I can “uninstall” them (or remove them from the list) is to temporarily rename the folder they are at and restart Rhino. But that doesn’t feel right.
Here I did that and restarted the wip:
(For some reason the size of the text and the tag icons are smaller on second start of the wip too. Probably a small glitch in the GUI settings or updating of such on first run)
But if I rename the folder back then the plugin is back too on next start of the wip:
I can through packagemanager if the plugins were installed from there though, But as you can see these are not registered there:
So would it not make sense to have an unistall option and not just the prevent from loading option?
