Will I have to install Windows 11 when the R9 is out or will I be able to use it on Win 10? I have a lot of problems on Win11 especially about PC running and heating like crazy although I am not running any tasks. I don’t want to go back to Win11. It would be great to have a Linux distro, btw.
Just a quick note: Windows 10 is a dead operating system that becomes less secure with every passing month, and no professional would use it anymore. I don’t know what system you have, but Windows 11 runs without issues on my Surface Laptop Studio 2—even though it’s a few years old—and I use it for complex tasks like extracting data from tunnel point clouds to reconstruct the entire structure as a 3D model, and so on.
Not yet.
Extended Security Updates (ESU) ends in October 13, 2026… and it’s not like on October 14 new crucial security bug will appear at unusual rate…
It will take months before an actual difference is relevant.
Hopefully they will further extend that period of ESU.
Lucky you you don’t care about what’s really happening.
Personally I don’t like having ads, apps installed without my permission, and AI leeching in my files and screen.
I tried it, and it required some time to fully debloat a W11 installation. And after every update it’s a gamble of which bloatware they manage to push back in the system. The situation is crazy.
Sorry, but I don’t have any ads or random apps that just get installed, and Copilot isn’t scraping anything. I have a clean Windows setup. It’s always the same childish exaggerations—but do whatever you want; that’s your decision.
It’s not childish and not an exaggerations, look it up.
I tried 11 some month ago and it had Netflix and other similar trash app pre-installed, and after an update some were installed again. I don’t do drugs
It’s full of people asking “how to prevent windows 11 update from reinstalling bloatware” and similar threads. Everywhere. “how to remove junk from 11”.
People found “Recall” feature enabled without they enabling it… the AI taking screenshots every x seconds…
If you don’t notice it and it doesn’t bother you, as said, lucky you. It’s still bloated nonetheless.
Windows 11 does not behave as a professional tool. Period.
Windows 10 is somewhat better at almost everything.
McNeel is forced to support only 11 for Rhino 9 … too bad.
That might be the case in your country, but here it is prohibited by law, and Copilot doesn’t take a screenshot every few seconds or anything like that. I can certainly understand why people find it a shame that Windows 10 is no longer officially supported—or rather, that there won’t be any support for it.
Note: To continue to receive critical and important security updates for Windows 10, see Windows 10 Extended Security Updates (ESU). Otherwise, we recommend you upgrade to a later version of Windows.
Last support for W10 IoT Enterprise LTSC 2021 is 2032, so I assume V9 will work on this version until then. I can install Rhino 2 and it still works fine on my current version.
We’re running Win11 Pro with no problems whatsoever - on some fairly dated PC’s even. The bloatware was limited to some X-box app and Office trial version. The Recall feature is NOT enabled by default, is only available on CoPilot+ PC’s, and the screenshots never leave your PC. I think that people claiming that it magically enabled itself, usually just went through the “welcome-screens” too fast. I’m not a big Microsoft fan, but think a lot of the Win11 bashing online comes from people using Win11 Home (which is indeed bloated) and/or just passing on tinfoil hat info from Reddit.
Just my 2 cents
-Jakob
I installed W11 Pro on 4-5 laptops (not mine), very bloated, even after un-flagging everything possible on the initial setup.
I don’t care what reddit says, I speak out of my personal experience.
Microsoft is trying hard to see how much they can push it over the limit.
Not for me, thanks.
OP too talks about lack of performance with 11 compared to 10.
Keeping the hardware new to not-perceive the under-performance of 11 might be a solution for someone… I prefer to value my money and use what I have until it really needs an upgrade.
I just wanted to say that officially W10 is still supported through ESU.
I’m not trying to convince anyone, I’m just stating what I think are facts.
Rhino 9 will run fine in Windows 10 but can’t we put it on the official supported list. Per usual if something arises in older OS compatibility we will do our best to keep it going on whatever Rhino version, if its within reach. At some point it becomes a bridge too far, especially with the MacOS changes.
