I was on my way to test the difference between between 48pix vs 256 setup with the same icons to see the size difference, if 256 made it excessive large. More on that later.
However I run into some problems when setting up first 48pix batch of test icons. For no good reason many of the icons turned grey. I tried a lot of different workarounds, copy the file, open them both and I got one that worked and one that did not i R9 okt10. Both opened well in R8 SR12. And in R9 the one with error start to work again as soon as I rename the RUI file. So to me it seems like it is not the files itself that have errors, but in some way how Rhino address the files, and that this connection can get corrupted.
2024.10.16 Test file PNG 48.rui (457.3 KB)
